Ford ATF Fluid or alternative for transmission?
Ive read alot of people opted out of using oem atf fluid and used instead the inexpensive ford atf or other compatible. is it still working after long term use of other fluids? how long have been running it. Which alternate fluid will you recommend that you know will play well with 2007 4.2 Q7? i am assuming is the G055? blue? any alternative ford or other?
I have heard of exactly zero people doing this. Where are you getting your information? I’d only use the recommended Aisin or ZF fluid to match your transmission.
I do think you are driving the wrong vehicle. Ford ATF should be for ford vehicles and not for a German made vehicle. Maybe that is why the manufactory claims no service needed which I don't believe myself on that theory. If the OEM fluid is too expensive for you, I recommend selling it and move to something else. Its just MHO.
Ford uses ZF transmissions and Ford uses Aisin transmissions. It could be that that some of the Ford fluid is exactly the same as what Audi uses. But how do you know? I'm not sure I'd have the wherewithal to figure it out, but with one vehicle to service every few years I doubt it would be worth the time to do the research, or take the risk without doing the research.
The following model use same type of ATF0T4 fluid. Or lots of people use mobil 3309.
Choose whatever is convenience for you.
You can check DIY fluid change at
https://www.clubtouareg.com/forums/f...atf-82168.html
AUDI Q3 2015-2016
AUDI Q7 2007-2010
AUDI TT 2003-2006
CHEVROLET AVEO 2004-2011
CHEVROLET AVEO5 2007-2011
CHEVROLET EQUINOX 2005-2009
CHEVROLET OPTRA 2004-2006
DODGE RAM 3500 PICKUP 2007-2010
FORD FIVE HUNDRED 2005-2007
FORD FUSION 2006-2012
HYUNDAI VERACRUZ 2007-2012
LAND ROVER LR2 2008-2009
LEXUS ES300 1999-2003
LEXUS ES330 2004-2006
LEXUS GS300 1993-2005
LEXUS GS400 1998-2000
LEXUS GS430 2001-2005
LEXUS GX470 2003
LEXUS IS300 2001-2005
LEXUS LS400 1990-2000
LEXUS LS430 2001-2003
LEXUS LX470 2003
LEXUS RX300 1999-2003
LEXUS RX330 2004-2006
LEXUS SC300 1998-2000
LEXUS SC400 1992-2000
LEXUS SC430 2002-2007
LINCOLN MKZ 2007-2010
LINCOLN ZEPHYR 2006
MAZDA 6 2005-2013
MAZDA CX-7 2007-2012
MAZDA CX-9 2007-2015
MAZDA MX-5 MIATA 2006-2016
MAZDA RX-8 2007-2011
MERCURY MILAN 2006-2009
MERCURY MONTEGO 2005-2007
MINI COOPER 2005-2015
MINI COOPER COUNTRYMAN 2011-2015
MINI COOPER PACEMAN 2013-2015
PONTIAC G3 2009-2010
PONTIAC G3 WAVE 2009
PONTIAC TORRENT 2006-2009
PONTIAC VIBE 2003-2008
PONTIAC WAVE 2006-2007
PORSCHE CAYENNE 2003-2010
RAM 3500 2011-2017
RAM 4500 2011-2016
RAM 5500 2011-2016
SAAB 9-3 2003-2011
SAAB 9-5 2002-2009
SATURN ASTRA 2008-2009
SATURN ION 2003-2004
SATURN VUE 2002-2003
SCION TC 2005-2006
SCION XA 2004-2006
SCION XB 2004-2006
SUZUKI GRAND VITARA 2006-2013
SUZUKI XL-7 2007-2008
TOYOTA 4RUNNER 2003
TOYOTA CAMRY 2002-2006
TOYOTA CELICA 2000-2005
TOYOTA COROLLA 2000-2008
TOYOTA ECHO 2000-2005
TOYOTA HIGHLANDER 2001-2007
TOYOTA LAND CRUISER 2003
TOYOTA MATRIX 2003-2008
TOYOTA PRIUS 2001-2003
TOYOTA RAV4 1996-2005
TOYOTA SEQUOIA 2003-2004
TOYOTA SIENNA 2004-2006
TOYOTA SOLARA 2002-2006
TOYOTA SUPRA 1993-1998
TOYOTA TACOMA 2003-2015
TOYOTA TUNDRA 2003-2004
VOLKSWAGEN BEETLE 2003-2014
VOLKSWAGEN CC 2009-2013
VOLKSWAGEN GOLF 2010-2016
VOLKSWAGEN JETTA 2005-2015
VOLKSWAGEN PASSAT 2006-2015
VOLKSWAGEN RABBIT 2006-2009
VOLKSWAGEN TIGUAN 2009-2015
VOLKSWAGEN TOUAREG 2004-2010
VOLVO C30 2008-2013
VOLVO C70 2001-2013
VOLVO S40 2001-2011
VOLVO S60 2001-2009
VOLVO S70 2000
VOLVO S80 1999-2010
VOLVO V40 2001-2004
VOLVO V50 2005-2011
VOLVO V70 2000-2010
VOLVO XC60 2010
VOLVO XC70 2003-2010
VOLVO XC90 2003-2012
No transmission fluid is lifetime. It needs to be changed at least every 100k. Heat breaks it done.
Audi and Ford share tech now, so you need to just match the specs.
so if i buy atf0t4/ type-iv fluid directly from toyota with toyota label on it, its the same as the audi one? meaning i can buy the cheaper one directly from toyota and it would work fine on the Q7?
You can find lots of discussions about this on toyota, lexus, and volvo forum as well as BITOG forum.
And you may want to check price of mobil 3309, cause Toyota T-IV is made by Mobil.
https://www.bobistheoilguy.com/forum...pics/2995984/2
BTW, the color of ATF0T4 is red, not blue.
PILL PUSHER
Audi allroad
11-26-2006 08:09 AM
Phil
10-29-2001 08:43 PM
