Key stuck in ignition, Q7 does not recognize it's in park
Using the keyless fob, I pushed the stop engine button in my garage when I finished my drive. The display screen suggested I place the vehicle in PARK to keep it from rolling. It was already in park though. I put the key in the ignition to see if it would recognize it and everything works fine except the key wont release when it's in the off position, the steering wheel won't lock either. For whatever reason, the vehicle thinks it's not in park when it is. Please help.
THANKS
THANKS
THANKS
THANKS
This may be of no help to you, but the same thing happened to me. After leaving it with the dealer to sort, they found a coin had slipped its way under the console, and was just stopping the lever registering being in Park. Amazingly it was free of charge. As I said probably no help to you, but look at the easiest first
Cheerd
Cheerd
Just a heads up. After finally finding a local shop that could scan the computer, there was a code pulling up for a faulty Transmission selector board. It's the electronic board under the console shifter. Almost a seven hundred dollar dealer part but I was able to get a complete unit from a low mileage used car off of ebay for about 200.00. As soon as the part arrives, I'll install it and keep everyone posted.
It happened to me one time, something stuck in the ignition. I pulled the key out, the stereo was still on. I used the new, seldom used 2nd key, put it in the ignition, turn the engine on and off. Pulled it in and out the ignition quickly, I heard something clicked inside the ignition, and it went away. It happened on a long trip, hot day. It actually happened twice with the same key on the same trip. The newer key never fails. Never happened again since, it was 2-3 years ago.
Good luck,
Louis
Good luck,
Louis
Guys , Brand new Q7 TDI. Have same error car not in park. After letting car sit for a few minutes the error goes away. sadly cant duplicate at dealer. Have pics to show but I guess they assume customers are idiots and don't know how to shift to park. Will see what happens .
Rob
Rob
