Keyless entry not working -
I've seen the posting from a bunch that are having the same problem, they say it's either the door handles or the ignition switch or the antenna.
Yes you can get a good idea from the VAGCOM, but I haven't heard of any one fixes the problem themselves out of warranty. Can you buy the parts ??
from looking at the ETKA it's not the door handle it's the micro switch (8H0959985B)or what they call the Bow(4L0839884A). can you buy these parts. I think if you can take the door apart
you can fix this stuff.. Is there a write up on how to take the doors apart? go to you tube and you can see guys taking the door handles off. Nothing to them unless
that's the model without keyless entry. I'm looking in to fixing mine and thanks every one there was a bunch of information in this forum. but I never heard of any one fixing it themselves.
my batteries were just replaced. The system die a slow death, borrowing a VAG to see what the codes are. I hope it's just the keyless antenna wherever that is. is there a part number for that ??
I get nothing any more. we can still use the key to open the doors like poor people use to. but that's no fun. Haven't tried the key less start yet , just I know the doors lock don't work with the keys. I want to fix mine because I want to trade my Q7 in. If any one has a 2013 with the tow package let me know but I have to get rid of my 2007 first or trade it in.
here's a short list of failures. I pulled the tire monitor fuse and turned off the module because we couldn't fix it and who cares so I had some failures because of that but I don;t under stand the battery management system, maybe pulling the fuse has an effect on that two. misfires are when the car is cold , we get alittle spudder right when you take off when it's cold. but I still don't have a check engine light. One thing at a time. look like the antenna is gone for the remotes. anyone tell me what might be gone here ?? cars a mess but runs great..
01-Engine -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G00 0447
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 68D4478D5B39297EC3-803C
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100602951
Coding: 0000135
VCID: 63CE50A1A21F4A2616-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
10 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
00193 - Rear Right Door Handle Touch Sensor (G418)
00956 - Key 2
002 - Lower Limit Exceeded
00192 - Rear Left Door Handle Touch Sensor (G417)
008 - Implausible Signal - Intermittent
00190 - Driver's Door Handle Touch Sensor (G415)
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
02639 - Antenna Reader for Keyless Access Authorization
011 - Open Circuit - Intermittent
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 354K.067514937
Coding: 0002003
VCID: 3874D7CD4B1979FE93-806C
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000591567
Subsystem 3 - Serial number: 0122.11.060000000100011350ÿ
Subsystem 4 - Serial number: 011350ÿ
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063290184
Coding: 0002042
VCID: 66C849B5512D3F0EF1-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
1 Fault Found:
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B138009
Coding: F753DE77747A02
VCID: 6CDC3B9D4FC1055EA7-8038
2 Faults Found:
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051787
VCID: 2F66EC91BE57BE46C2-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01025882110000
Coding: 4487197
VCID: 3162EAE9A863A8B6D4-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000059165
Coding: 0012001
VCID: 5EB86155897D67CE39-800A
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051787
1 Fault Found:
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000063520
Shop #: WSC 09401 444 82758
VCID: 64CC53BDA7114D1EEF-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 0987654321
Coding: 344630393135313035442056413030393837363534333231
Shop #: WSC 08148 444 101460
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
1 Fault Found:
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002211739-----
Coding: 0003595
VCID: 264809B591ADFF0E31-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
2 Faults Found:
01514 - Regulator for Roof
012 - Electrical Fault in Circuit - Intermittent
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
2 Faults Found:
End-------------------------(Elapsed Time: 03:05)--------------------------
Coding: 0001175
5 Faults Found:
000769 - Cylinder 1
000770 - Cylinder 2
000772 - Cylinder 4
000771 - Cylinder 3
Coding: 0000135
10 Faults Found:
00956 - Key 2
Coding: 0002003
1 Fault Found:
Coding: 0002042
1 Fault Found:
2 Faults Found:
Revision: 00-00000
Coding: 0051787
1 Fault Found:
Coding: 4487197
1 Fault Found:
Coding: 0012001
1 Fault Found:
Revision: 00-00000
Coding: 0051787
1 Fault Found:
2 Faults Found:
Coding: 0051722
1 Fault Found:
Coding: 0003595
2 Faults Found:
Coding: 0051722
2 Faults Found:
Have you had a flat battery lately?
Looking that all 4 door handles are knackered.
I would first say make sure battery is charged then clear all codes.
Next try to firstly lock car by pressing the button on each handle to see if it responds. if it locks of one pressing the next will still flash indicators if working.
Then try to unlock by touching each handle. id none work gently pull the handle to see if that works if it does the handle may be working but the other on that side is stopping it.
Then rescan and post.
Battery has to be fully charge.
ok I'll try it but we haven't had any problems with the battery car seems to drive and be normal. I think there are multiple problems here, I think the remote key antenna is shot - TSB for it. when I push the start button for the key-less start the remote lights up like normal just nothing happens. the car can't see the key unless I stick it in the ignition. all the door handles are dead like most have experienced. I don;t care if they ever work again. but I'd like to get the remote fob to at least unlock the doors. trying to get some of this stuff fixed before I trade it in.. not sure I can get parts anyway. I have to believe you can take the door handle or the door electronic out and fix it. Got a guy in the lab at work that might be able to if I can take the handles apart. don't know if there are service able or not. any one found a cheap place to buy them?? yes I know you have to have them painted. I'l try what you suggested and repost. remember I turned off the tire pressure monitor system and pulled the fuse. that may have triggered some other fault. just trying to get the remote to work to unlock the doors.
Trying to take each one that could cause most of the problems.
00956 - Key 2 (Who has this key two?)
00956 - Key 2: Adaptation Limit Surpassed
Possible Symptoms: Remote control not working.
Possible Causes: Key not matched.
Key operated more than 200 times while out of range.
Q7 keyless TSB].pdf
02639 - Antenna Reader for Keyless Access Authorization (was cause by your key 2)
02072 - Control Module for Energy Management (J644) ( your main battery went below the require 12v)
(Quick Idle Current Measurement can be performed in the
Guided Fault Finding or Guided Functions modes, under
“61 Battery Control – Idle Current Measurement with the
Energy Management Control Module J644.”
The following data records are available:
Idle voltage history
Idle current history
Critical energy balance
Power-down level history
Battery change history
Energy balance of the last 5 trips
Energy balance of the last 5 downtimes
Date/time programming in the instrument cluster
The battery can now be tested using Scan Tool VAS 5051b
via the Energy Management Control Module J644. This
test can be started in the Guided Fault Finding or Guided
Functions mode under “61 battery control - A battery,
test”.)
Extended durations with voltage below 12.2 V and
11.5 V are particularly critical. Below these voltages, the
battery is unable to regenerate. The battery can then
be damaged by long periods of downtime. If extended
durations with voltage below 12.2 V and 11.5 V are
identified, the battery must be tested.
The data is recorded under the following conditions:
Terminal 15 off for at least 2 hours
Comfort System CAN-bus in sleep mode
Current draw less than 100 mA
wire chart of the keyless
Q7 Diagram 18:7 (Tracks 71-84) keyless door.pdf
Q7 Keyless Access Authorization .pdf
You do not show a bad ANT control module J723.
Hope this helps
Q7 keyless TSB].pdf
test”.)
Hope this helps
So you think the keys need to be re-adapted to the car. maybe the battery was low in remote and it didn't work very well and my wife tried it a ton of times. I don't understand the car battery stuff, I've never had a problem with anything that battery is maybe two years old. what about the door handles being bad , I read it's a whole complete system if the handles don't work neither does the remotes or the keyless start. Acc/start module faults.. can you match keys or remotes with the VAGCOM?? not sure why both remotes don't work.. I'll have to do the batter test while I have the VAG COM.
If your wife is like my wife, she will wear out the buttons on the key. I've replaced the batteries is both main keys on the 4.2 now twice in less than two years. One was completely dead, the other had a dramatically shorter range and wouldn't open the rear hatch.
The 3.6 just has a bad antenna (broken solder joint at window I'm guessing), as one of the keys is only about 1.5 months old, two tops, and it has a VERY short range of 5-10ft.
where is the antenna in the car , any pictures so I can check it?? can the VAGCOM check the anntenna ?? I've heard of a bad ignition switch too. All I want is to the the remotes working again and the keyless starting . I don't care about the door handles.. the energy manager system could be a bad module also, I'll see if I can test that tonight with VAGCOM or at least grab some data. I hope I don't have to take it some place to remarry the remotes.
