LED Interior light conversion
#11
Thru my own ineptness I accidentally ordered the kit for 07-09 Q7. I discovered my mistake & called them this morning. A very helpful gentleman tracked down my order, made sure it hadn't shipped & made sure the right kit for my 2013 would be sent. A few minutes later I got an e-mail saying my order had shipped first class mail.
Hopefully I'll be able to get them installed early next week & I'll try & post results.
#14
Ordered online from Tunerdomes late Thursday night & despite my screwup in ordering the wrong part# I received my order via U.S. mail on Monday. Great service.
Installation overall was very simple - just use a sturdy plastic tool (I invested in an inexpensive set of interior trim removal tools). All the fixtures come out with firm, gentle pressure. The trim around the front dome & map lights comes down by opening the glasses holder & pulling down gently. Most of the bulb fixtures have plastic enclosures around them - you just have to use a small screwdriver to release them. The map lights in the front were probably the worst. They're bayonet types & there's not a lot of room to get your fingers in there & push in and turn at the same time. Patience and a tight fitting vinyl glove helps get a little more traction. As someone else mentioned in another thread - put a towel over the center console & cover the entrances to the bottomless cavern under the front seats. You're going to drop one of those bulbs at least once & the towel not only protects your center console, it will keep things from disappearing, never to be seen again.
The four puddle lights under the doors are kind of a pain since you have to lie on your back on the ground, but they pop out easily & the bulbs just slide in.
Overall, the change out is a fairly easy job. LEDs are polarity sensitive so you've got a 50/50 chance of being right the first time - unless Murphy lives in your neighborhood, in which case you'll end up turning about 75% of them around to make them come on.
#15
A4tooS4-LAbull
09-15-2005 02:39 PM
JimmY@RojoCollisioN
19
12-19-2001 01:46 PM
Bracketracer
29
12-17-2001 10:39 PM
