Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 2008 Liftgate Will Not Close
Old 01-23-2019, 06:44 AM
lspviii's Avatar
Default Q7 2008 Liftgate Will Not Close
I have a 2008 Q7 3.6Prem. When I try to close the liftgate using the button on the liftgate it does not close. If I stop the liftgate as it is opening, I can press the button in the liftgate and the liftgate will open completely. Therefore, it appears as if the button is working. It just doesn't want to work when I am trying to close it. I have to manually close the liftgate. I have also tried holding the button to try to set the height but that doesn't appear to work either. If I recall there is supposed to be a confirmation sound like a beep but nothing. Any ideas on what might be wrong? Thanks.
Old 01-24-2019, 05:24 AM
Up-it's Avatar
If you press the outwr button to raise when its closed and let it go say only half way and stop it, what happens when you press the close button located on the inner trim the boot lid? It should close back down, if it doesn’t there is a high chance that with many other q7’s with age that one of the 2 electric tailgate motors is failing, the lid use about 50% rear gas struts and 50% electric motors to raise. When closing it has to use 100% electric motors so if their in bad shape you will have a hetic time with the closing. I have had the same problems with mine and replaced both motors with 2 second hand units and it was all fixed. See how you go?
Old 01-24-2019, 07:13 AM
lspviii's Avatar
When I press the button under the hatch as you describe the liftgate will completely open.
Old 06-24-2019, 04:05 PM
jeffkruse's Avatar
Default Did you ever get the liftgate figured out?
What was it if you did?
mr8q7
Q7 MK 1 Discussion
11-24-2018 01:02 AM
pr4nkster
Q7 MK 1 Discussion
12-27-2017 06:17 AM
Jefferz
07-08-2013 05:43 AM
4ktq_smin
04-02-2004 04:27 PM
MatthewZ
06-13-2002 04:41 AM
Quick Reply: Q7 2008 Liftgate Will Not Close
