Q7 glowing LED
Q7 glowing LED
so I have noticed as I walk out to my 2010 Q7 Prestige that there are 2 LEDs faintly glowing in the yellow directional on the drivers side next to the Headlight.
is this something that is normal and this is my first notice?
Not full brightness to see during the day but you can see the glow at night
just had a ton of work done on the Q7
independent shop said codes pointed to timing chain but they checked out and they went thru the total top end including injectors replacement and shell blasting the valves. odd thing is my app based code reader did not show the code as a check engine light code
AudiWorld Expert
it could be a couple of things but the easiest would be first check to see if your indicator stalk is in the off position when you shut off the vehicle. if it persists then something is wrong. those lights (along with the fogs & tail lights) should not be on longer than 90 (?) seconds if you have the feature enabled.
bugbbq
08-31-2001 05:34 PM
zero2130
04-17-2001 08:09 AM
