Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Tire tread depth difference
Old 06-03-2014, 11:48 AM
igork007's Avatar
Default Tire tread depth difference
Hi all,
I have a '13 Q7 TDI with 275/45/20 tires. Due to various blow-outs I have a variety of tread depths and need some advice.
Fronts are 7/32 and 10/32
Rears are both 4/32
Is this tread depth difference going to cause an issue and should I replace the rears immediately or can I wait for a little while?
Thanks in advance!
Old 06-03-2014, 12:45 PM
SlizSam's Avatar
Your Rears are close...per Tirerack.com:
"The Law
According to most states' laws, tires are legally worn out when they have worn down to 2/32" of remaining tread depth. To help warn drivers that their tires have reached that point, tires sold in North America are required to have indicators molded into their tread design called "wear bars" which run across their tread pattern from their outside shoulder to inside shoulder. Wear bars are designed to visually connect the elements of the tire's tread pattern and warn drivers when their tires no longer meet minimum tread depth requirements.
Common Sense
However, as a tire wears it's important to realize that the tire's ability to perform in rain and snow will be reduced. With 2/32" of remaining tread depth, resistance to hydroplaning in the rain at highway speeds has been significantly reduced, and traction in snow has been virtually eliminated.
If rain and wet roads are a concern, you should consider replacing your tires when they reach approximately 4/32" of remaining tread depth. Since water can't be compressed, you need enough tread depth to allow rain to escape through the tire's grooves. If the water can't escape fast enough, your vehicle's tires will be forced to hydroplane (float) on top of the water, losing traction.
If snow-covered roads are a concern, you should consider replacing your tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. "
KillA6
11-07-2007 09:33 AM
allroadbryan
Audi allroad
12-22-2006 01:53 PM
AndrewJM
12
09-08-2005 11:00 AM
tppatron
Wheels & Tires Discussion
03-17-2004 08:39 AM
VladN
01-28-2002 10:02 AM
Quick Reply: Tire tread depth difference
