Rear bumper/spoiler upgrade
#11
i got this off ebay, already in relfex silver for £30 delivered.
but these are just removable. so you can just remove the original no problem and paint it yuorself and reinstall.
it is in three sections, they just unclip from the bumper. the centre section covers the towing arrangement if not installed and is the easiest to remove. the section either side are a bit trickier, but there is no screws or anything, it is just clipped in.
#15
And here are the part numbers you need. I tossed in the exhaust tips as well just in case you want them (I think they only fit the 3.2 and TDI.. but i could be wrong.) I also added the new 2010/2011 tail lights.. so my Q7 now has a 2010/2011 rear.
Rear bumper lower 4L0 807 434 M GRU $371.25
Rear bumper insert 4L0 807 833 A 3FZ $ 69.00
Ehaust tips 4L0-071-060 $155.00
Jim, Thank you for your inquiry with AudiUSAParts.com. In looking into this conversion the part numbers you have given are good for the 2010 with the newer honeycomb style spoiler. Our only concern is that the actual bumper cover for your 08 is different from the 2009 and newer styling. Your 08 has the impact beam in the bumper where the newer models have it separate. This is not to say this update will not fit, we just have not tried it. We have linked the parts to this email below for ease of ordering. 4L0807434MGRU spoiler is $390, the honeycomb grille is $71.25 and the exhaust tip kit is $132.13. Freight would be about $75 Ground UPS oversized to 91351. We can do some additional investigating to see if the bumper cover shapes are the same, if so there should not be any issue changing out the spoilers--great idea. Thank you again for the request, please let us know how we can help in the future. Hope to hear from you soon, have a great evening. Loree Leonard AudiUSAParts.com 1-877-601-3061
Any thoughts Greg.....or anyone else?
#16
Greg.....you still out there? I'm finally moving into this mod and thought I'd check parts prices around a bit before I order. I got this reponse from one of my inquirys:
#18
#19
For 2008.. (it should be identical to 2009 for USA models... so I still don't think the imact beam is an issue.. it should be part of the upper bumper.. not the lower spoiler. Obviously i can't confirm this... but just look under your car (or pull your bumper off and take a look.)
#20
Can you update a not-sline and not-facelift Q7 with any S-line rear lower bumper / spoiler?
I'd like to do this mod but I am unsure about the compatibility. Based on this thread all s-line rear spoilers are compatible with each other.
