Transmission Issues - Help! :(
#11
#12
Wow, just- wow. I really, really appreciate those sentiments, Grey! Thanks! Here's hoping!
#13
Yes, I am actually right on the town line of Woodinville/Bothell WA. 240th St SE & 45th Ave SE, In Olympic Ridge. Geez, if you could help that would be absolutely amazing. Perhaps an evening this week??
~George
#14
Most of those codes are not even engine related, and the ones that are, do not seem to be that serious.
The one I would be looking at is the Transmission Code for gear ratios.
Clear the codes one at a time, with the particular controller.
Some of them my come right back, I have a parking assistant error that will not clear, because it is a short to ground.
Good Luck
Good Luck
#15
I cleared all codes. I haven't driven it yet. Idling, waiting for car to get good and hot. I have several codes that came back immediately after clearing several times. 2 HVAC faults and 4 door faults. Outer door unlock sensors and front & rear HVAC sensors. Every time I clear them they come right back. So, obviously something is very broken there, but I'm not worried about those right now.
Everything else is clear and holding clear while idling.
This particular VagCom tool doesn't seem to have any options to do those steps you provided in the tranny adaptation procedure. So, I would really like to take you up on your offer to try and set those with your UBER tool! Haha!
In the meantime, I am going to take it for a ride and see what happens... will run another scan when i come back. Will update with status!!
~George
#16
UPDATE:
I cleared all codes. I haven't driven it yet. Idling, waiting for car to get good and hot. I have several codes that came back immediately after clearing several times. 2 HVAC faults and 4 door faults. Outer door unlock sensors and front & rear HVAC sensors. Every time I clear them they come right back. So, obviously something very broken there, but I'm not worried about those right now.
~George
~George
What you want to watch for are the Trans codes after you drive it a bit. Then do a Google Search and see what comes up on them.
#17
Originally Posted by George Trudeau
I re-borrowed that cable and am in the car now trying to figure out how to clear everything. Haha. I guess we will see.
Yes, I am actually right on the line, of Woodinville/Bothell WA. 240th St SE & 45th Ave SE, In Olympic Ridge. Geez, if you could help that would be absolutely amazing. Perhaps an evening this week??
~George
~George
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Grey
#18
My laptop and VagCom was running the whole time so I scanned codes. seemed clear as a bell. All good- Although, another 'lean' code popped up which is irritating me since I replaced both MAFs already. I cleared it. Went to transmission, and nothing. BUT, for giggles, I put it into reverse & drive a couple times to see how it was behaving, and that thumping was still there. Re-ran diagnostic, and sure as it rains all winter in the Pacific Northwest; there was a tranny code:
Sunday,12,November,2017,20:13:20:61691
VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 02: Auto Trans Labels: 09D-927-750.LBL
Control Module Part Number: 09D 927 750 FQ HW: 09D 927 750 FQ
Component and/or Version: AL 750 6A 0999
Software Coding: 0000504
Work Shop Code: WSC 31414 790 00001
VCID: 02008CB65DFFEA569C-8056
1 Fault Found:
17114 - Gear Ratio Monitoring
P0730 - 003 - Incorrect Gear Ratio
SO- I am still not sure if something is broken, or, if #Raj99 is correct and the adaptive reset needs to happen. either way, I am open to trying it Raj99!! I'm sure giving it a go costs less than what a shop would!!
Also- the HEX+CAN wouldn't allow me to do anything with the "Adaptation". The entire box was greyed out
Back to square 1.
#19
17114/P0730/001840 - Gear Ratio Monitoring: Incorrect Gear Ratio
Possible Symptoms
- Malfunction Indicator Light (MIL) ON
Possible Causes
- Transmission Fluid contaminated
- Transmission faulty (Mechanical Problem)
Possible Solutions
- Check Transmission Fluid (Color and Contamination)
- Replace Transmission Fluid when necessary
- Check Transmission Mechanics
So based off of that- The cooler makes sense. It was AWESOME until I stomped on it. Maybe it's getting too hot??
I mean guys, this thing was amazing- PERFECT for 20 minutes of driving until I hammered it once for 4-5 seconds. I wouldn't think the transmission was toast if it was acting so good beforehand!
Frustrated. And, I know a mechanic will tell me to replace the whole transmission.
#20
Good Luck
Good Luck
The gear ratio one did pop back (see my last update). This, REALLY concerns me.
