Transmission Park Selector Switch (F305) - DTC 00230
Been having an issue that has been discussed on here. Q7 is intermittently displaying a problem that it is not recognized in park and will not allow me to lock the doors. I plugged it into VCDS and recieved this:
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 128925 km
Time Indication: 0
Date: 2014.09.07
Time: 07:03:35
So I went through all my trusty Audi Maintenance manuals and was unable to find a repair/replace procedure for the F305 module. Additionally I was able to find a blown up parts diagram here however I'm not sure which module is the F305.
Any help would be appreciated with a replacement procedure and/or a part number!
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 128925 km
Time Indication: 0
Date: 2014.09.07
Time: 07:03:35
B490MTL, I was actually just reading that when I noticed you replied! There is some great info in there. I used the drawing in the training document to cross reference the part.
Part is located here.
Audi Part Number: 4F0927353A
Item Number 15 in the blown up diagram below.
I hope this helps out anyone else that see's this issue. Apparently Audi charges hundreds of dollars to fix a $20 part...
absoluteaudiCS
Audi 100 / A6 (C4 Platform)
10-23-2005 11:09 AM
Avant Eric
07-18-2005 04:04 AM
