Well my Q7 is out of service.
Even my indy has problems figuring out the problem. The truck flashed esp and said to refer to the owner manual, then coming to a stop it flashed esp with epc and the check engine light got on. It stalled and displayed key not recognized. (I have push button start). I took the key out and started the truck from the keyhole just fine, no lights on. Finished work, get in my truck, nothing! Once turned on, the esp is on, the transmission display is reverse lit, epc is on and the cooling fan are on at 100%. These are the codes I pulled, anyone encountered the same problem?
Saturday,05,March,2016,17:12:24:13728
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WA1BY74L97D086842 License Plate: G41 EAV
Mileage: 211260km-131270mi Repair Order: ecm
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 3C 42 46 47
4F 52 55 56 61 62 65 67 69 6C 6D 6F 72 76 77
Mileage: 211260km/131270miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans Labels: None
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0020
Revision: --H01--- Serial number: 0000999
Coding: 0000002
Shop #: WSC 00000 000 00000
VCID: 2953E64E80CC8256E3D-807C
2 Faults Found:
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 1.0°C
T.B. Angle: 60.0°
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
Shop #: WSC 31414 790 00001
VCID: 2855E34A9BC6BB5EFC3-807D
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:35
Freeze Frame:
Count: 64
Count: 8193
Count: 8194
Count: 41216
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100679158
Coding: 0000135
VCID: E3CF346622609806691-80B6
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
3 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:07
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:07
00190 - Driver's Door Handle Touch Sensor (G415)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:08
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 354BX077517956
Coding: 0002003
Shop #: WSC 93250 999 105176
VCID: 3875330A4B662BDE6C3-806D
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001666554
Subsystem 3 - Serial number: 0131.08.100000000100010393ÿ
Subsystem 4 - Serial number: 010393ÿ
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030029307
Coding: 0524326
VCID: E1C33E6E387C8A167BD-80B4
2 Faults Found:
02874 - Control Module 2 for Central Convenience (J773)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:04:53
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 211267 km
Time Indication: 0
Date: 2016.03.05
Time: 00:39:26
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H29 0390
Revision: 00000000 Serial number: 4F0907279
Coding: 0133124
VCID: 6ED9D55279A2A56E76F-803B
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H15 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00215595
Shop #: WSC 31414
3 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:15:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:15:00
00924 - Relay for Headlamp Cleaning System (J39)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:05:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H43 0390
Revision: 00043000 Serial number: AUZ5ZBG1038190
VCID: 1E39C592C98275EE86F-804B
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0162042
Coding: 0000100
VCID: 2F670856BE28EC663D9-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 13
Mileage: 210769 km
Time Indication: 0
Date: 2016.02.21
Time: 12:18:04
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 75 AIRBAG AUDI8RH41 0230
Revision: 05H41000 Serial number: 0038QD053N61
Coding: 0014133
VCID: 2B5F1C468A309046111-807E
Subsystem 1 - Serial number: 6332QSME22412C0DB
Subsystem 2 - Serial number: 6342QSME22411D7BH
Subsystem 3 - Serial number: 6352QSME21544C61C
Subsystem 4 - Serial number: 6362QSME206D0D67P
Subsystem 5 - Serial number: 63734SME1E0B1613
Subsystem 6 - Serial number: 63834SME1E0918451
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90026070320027
Coding: 0002242
VCID: 2757E07696D8B426F59-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 930 G
Component: KOMBIINSTR. M73 H18 0170
Revision: 00200000 Serial number: 5HF31HH27
Coding: 2641333
Shop #: WSC 02185 099 00999
VCID: 234FF466E2E05806A91-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 33
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:35
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D071228264
Coding: F7D7FE77747A02
Shop #: WSC 93023 999 83911
VCID: ECDD5F5ACFBED77ED8B-80B9
3 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 211048 km
Time Indication: 0
Date: 2016.02.27
Time: 16:41:32
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 210886 km
Time Indication: 0
Date: 2016.02.24
Time: 13:13:52
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 85
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 020000
VCID: 2B5F1C464A309046111-807E
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 L
Component: MNS US H48 0960
Revision: 00000000 Serial number: 313AJ077517066
Shop #: WSC 93023 999 85814
VCID: 2E591552B922E56E36F-807B
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 4
Reset counter: 64
Mileage: 210555 km
Time Indication: 0
Date: 2016.02.17
Time: 12:24:11
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0010001
VCID: 2D5B125EB4249E760F5-8078
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F18.01.0700H0600000010290ÿ
Subsystem 4 - Serial number: 010290ÿ
1 Fault Found:
02856 - Sensing Area for Control Module 2 Blocked
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 210684 km
Time Indication: 0
Date: 2016.02.20
Time: 01:36:09
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01323580570000
Coding: 7637021
Shop #: WSC 49158 001 104857
VCID: 356B3A3E5C74D6B6775-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 45
Mileage: 211266 km
Time Indication: 0
Date: 2016.03.04
Time: 15:13:23
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000073175
Coding: 0002001
VCID: DEB905920902B5EE46F-808B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:00
Freeze Frame:
Voltage: 11.300 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 45
Mileage: 198378 km
Time Indication: 0
Date: 2015.08.05
Time: 12:09:39
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 35
Reset counter: 45
Mileage: 211240 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388B 077590917
Coding: 0000002
VCID: 31630E2EA81CFA962BD-8064
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 88
Reset counter: 245
Mileage: 188960 km
Time Indication: 0
Date: 2015.03.10
Time: 09:04:55
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000004488
VCID: E4CD377A276E9F3E90B-80B1
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 K33K22AHUL
Coding: 34463039313531303544205641304B33334B32324148554C
2 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 210978 km
Time Indication: 0
Date: 2016.02.26
Time: 22:23:46
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 45
Mileage: 211265 km
Time Indication: 0
Date: 2016.03.04
Time: 12:22:08
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700042324
Coding: 0062424
VCID: 2241F162FDFA510EA27-8077
1 Fault Found:
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 211267 km
Time Indication: 0
Date: 2016.03.05
Time: 17:10:31
Freeze Frame:
(no units): 0.0
Voltage: 13.20 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000701270030
Shop #: WSC 12336 024 394758
VCID: 346D073A570ECFBE40B-8061
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000002
VCID: 244DF77AE7EE5F3ED0B-8071
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:00
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7140UH
Coding: 1101201
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD15.02.07--H21001000A0137ÿ
Subsystem 4 - Serial number: 0A0137ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002480328-----
Coding: 0003855
VCID: 2649ED7291D2AD2ECEF-8073
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
1 Fault Found:
02906 - Control Module for Sliding Roof; Rear (J392)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 241
Reset counter: 45
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:09:30
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230702000749
Coding: 0231246
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 85
Mileage: 210867 km
Time Indication: 0
Date: 2016.02.23
Time: 07:30:17
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005016138
Coding: 0010900
Shop #: WSC 93250 999 04969
End ---------------------------------------------------------------------
Chassis Type: 4L0
Address 01: Engine
Cannot be reached
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 1.0°C
T.B. Angle: 60.0°
U0100 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Revision: 00H22001
Coding: 0033809
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:35
Freeze Frame:
Count: 64
Count: 8193
Count: 8194
Count: 41216
Coding: 0000135
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:07
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:22:08
Coding: 0002003
Coding: 0524326
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:04:53
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 211267 km
Time Indication: 0
Date: 2016.03.05
Time: 00:39:26
Coding: 0133124
Coding: 00064792
Shop #: WSC 31414
Coding: 00215595
Shop #: WSC 31414
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:15:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:15:00
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 210852 km
Time Indication: 0
Date: 2016.02.22
Time: 20:05:00
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 13
Mileage: 210769 km
Time Indication: 0
Date: 2016.02.21
Time: 12:18:04
Coding: 0014133
Coding: 0002242
Coding: 2641333
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 33
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:35
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 211048 km
Time Indication: 0
Date: 2016.02.27
Time: 16:41:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 210886 km
Time Indication: 0
Date: 2016.02.24
Time: 13:13:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 85
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Revision: 00000000
Coding: 020000
Coding: 0082954
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 64
Mileage: 210555 km
Time Indication: 0
Date: 2016.02.17
Time: 12:24:11
Coding: 0010001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 210684 km
Time Indication: 0
Date: 2016.02.20
Time: 01:36:09
Revision: 00-00000
Coding: 0051915
Coding: 7637021
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 45
Mileage: 211266 km
Time Indication: 0
Date: 2016.03.04
Time: 15:13:23
Cannot be reached
Coding: 0002001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:00
Freeze Frame:
Voltage: 11.300 V
Temperature: 77.0°C
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 45
Mileage: 198378 km
Time Indication: 0
Date: 2015.08.05
Time: 12:09:39
Coding: 0000021
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 35
Reset counter: 45
Mileage: 211240 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:34
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 88
Reset counter: 245
Mileage: 188960 km
Time Indication: 0
Date: 2015.03.10
Time: 09:04:55
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 210978 km
Time Indication: 0
Date: 2016.02.26
Time: 22:23:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 45
Mileage: 211265 km
Time Indication: 0
Date: 2016.03.04
Time: 12:22:08
Coding: 0051722
Coding: 0062424
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 211267 km
Time Indication: 0
Date: 2016.03.05
Time: 17:10:31
Freeze Frame:
(no units): 0.0
Voltage: 13.20 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 45
Mileage: 211236 km
Time Indication: 0
Date: 2016.03.03
Time: 12:18:00
Coding: 1101201
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Coding: 0003855
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 45
Mileage: 210414 km
Time Indication: 0
Date: 2016.02.14
Time: 16:09:30
Coding: 0051722
Coding: 0231246
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 85
Mileage: 210867 km
Time Indication: 0
Date: 2016.02.23
Time: 07:30:17
Coding: 0010900
B490MTL:
Check your Alternator; voltage regulator. Looks like it is over charging and when it does it will shut down.
You have mention no lights, plus a no start.
+1. Use VCDS to check your battery condition first. Seeing that your Q7 has already logged more than 130k miles, is the battery new or old? If old, I bet that you battery is dying or just about to go flat.
Battery was changed last year, it is at my indy right now, and the "low battery charge, will recharge during driving" turned on. It really sounds like Gavin0478 said a ground or connector that went bad.
I also think it is a loose ground - who changed the battery last year?
I would get out your 10 mm triple square socket and tilt the seat back - there are several ground connections there including one next to the front/middle bolt.
Removing the battery on a Q7 - Page 2 - AudiForums.com
Good luck and report back.
I'll forward the info to my indy, I changed the battery myself last year but it started acting up a day after a snow storm so maybe the answer is in the driver floor since there is a couple of grounds there too.
A little update, my indy is still working on and off on it, the engine computer seems to be in a sleep state like someone flashed it but failed. I'll keep you guys posted.
