09 Q7 TDI - CEL light came on
Thanks
Sunday,08,March,2015,17:29:29:21918
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1
Data version: 20150130
Dealer/Shop Name: 0000
VIN: WA1AM64L49D034796 License Plate: 1234
Mileage: 109450km-68009mi Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 55 56
62 65 69 6C 6D 6F 72 76 77
VIN: WA1AM64L49D034796 Mileage: 109450km-68009miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CAT) Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 Q HW: 4L0 907 401 B
Component: 3.0TDI EDC17G000AG 0080
Revision: 31H01--- Serial number:
Coding: 0121002A190F0168
Shop #: WSC 95982 999 122183
VCID: 306F309DA376CDA1DE0-8065
6 Faults Found:
000554 - Charger Air Cooler Bypass Control A
P022A - 000 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 212
Reset counter: 255
Mileage: 109424 km
Time Indication: 0
Date: 2015.03.01
Time: 12:53:46
Freeze Frame:
RPM: 777 /min
Speed: 0.0 km/h
Voltage: 14.21 V
Temperature: -6.3*C
Bin. Bits: 00000000
Duty Cycle: 81.6 %
Temperature: 4.5*C
000587 - Charge Air Cooler Bypass Control A
P024B - 000 - Stuck - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 109425 km
Time Indication: 0
Date: 2015.03.01
Time: 12:59:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.46 V
Temperature: -6.3*C
Bin. Bits: 00000000
Duty Cycle: 4.7 %
Temperature: 6.3*C
000586 - Charge Air Cooler Bypass Control A
P024A - 000 - Implausbile Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Mileage: 109456 km
Time Indication: 0
Date: 2015.03.07
Time: 22:25:27
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.01 V
Temperature: -6.3*C
Bin. Bits: 00000000
Duty Cycle: 4.7 %
Temperature: 9.9*C
000555 - Charger Air Cooler Bypass Control A Circuit
P022B - 000 - Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 87
Reset counter: 255
Mileage: 109427 km
Time Indication: 0
Date: 2015.03.01
Time: 13:55:24
Freeze Frame:
RPM: 777 /min
Speed: 6.7 km/h
Voltage: 13.91 V
Temperature: -6.3*C
Bin. Bits: 00000000
Duty Cycle: 27.0 %
Temperature: 3.6*C
008265 - Reductant Injector Bank 1
P2049 - 001 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 13
Reset counter: 255
Mileage: 109441 km
Time Indication: 0
Date: 2015.03.03
Time: 17:16:03
Freeze Frame:
RPM: 840 /min
Speed: 0.0 km/h
Voltage: 14.29 V
Temperature: -6.3*C
5.0 bar
Temperature: 42.0*C
Temperature: 194.7*C
008263 - Reductant Injector Bank 1
P2047 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 109440 km
Time Indication: 0
Date: 2015.03.03
Time: 17:04:33
Freeze Frame:
RPM: 777 /min
Speed: 0.0 km/h
Voltage: 14.14 V
Temperature: -11.7*C
5.0 bar
Temperature: 12.0*C
Temperature: 147.5*C
Readiness: 1 5 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FD HW: 09D 927 750 FD
Component: AL 750 6A 1474
Revision: 00H78000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 75E1C1891C94A8894D6-8020
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0099473
VCID: 2959DDF980ACBC6919E-807C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601267234
Coding: 0000131
VCID: 2541D1C9ECB498093D6-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 354AV097546753
Coding: 0002003
VCID: 387F08BD4B0615E1960-806D
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001937395
Subsystem 3 - Serial number: 0103.11.110000000100010493ÿ
Subsystem 4 - Serial number: 010493ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 N
Component: KLIMABETAETIGUNGH07 0040
Revision: 00---014 Serial number: 00000000196745
Coding: 0000054
VCID: 2345CFD1E2806639532-8076
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0012114
VCID: 34673C8D576EF181BA8-8061
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00022806
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H46 0390
Revision: 00046004 Serial number: AUZ5ZBI8734937
Shop #: WSC 00000 000 00000
VCID: 1E33FE25C9E24BD17CC-804B
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 75 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD097EHB
Coding: 0014133
VCID: 2B5527F18A50AE79EB2-807E
Subsystem 1 - Serial number: 6332QSME09061F18F
Subsystem 2 - Serial number: 6342QSME04061B10%
Subsystem 3 - Serial number: 6352QSME5A1F193AV
Subsystem 4 - Serial number: 6362QSME6118352EI
Subsystem 5 - Serial number: 63734SME430E3330V
Subsystem 6 - Serial number: 63834SME430E3608/
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90026083400062
Coding: 0002242
VCID: 275DDBC196B88A190FA-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 900 L HW: 4L0 920 900 L
Component: KOMBIINSTR. H06 0135
Revision: 00100000 Serial number: AEN23JW19
Coding: 8B96640401000008020300
VCID: 306F309D6376CDA1DE0-8065
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 K HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0025
Revision: 4LA80024 Serial number: 2400L091138184
Coding: 000303
VCID: 377D0B8186181A999FA-8062
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0107
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001212321
Coding: 00581300000011110000
VCID: 31693599687CC4A9D1E-8064
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100668627
Coding: 010D07205E40440004
VCID: 46837645F1F2731114C-8013
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H08 0060
Revision: 0060 --- Serial number: 01159471290000
Coding: 3438621
VCID: 33653F915260F6B9A32-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 910 223 K HW: 4L0 035 223 C
Component: DSP-AU716-RD H07 0270
Revision: S1100000
Coding: 020000
VCID: 2C5724ED4F5EA941E28-8079
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000050013
Coding: 0012001
VCID: 5EB3BE2589620BD13CC-800B
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100657976
VCID: 45817149CCF478091D6-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000007
VCID: 3F8D63A16E2822D957A-806A
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 304AI097632209
Coding: 0000002
VCID: 31693599A87CC4A9D1E-8064
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100662171
Coding: 010C07204040230004
VCID: 43856F51C2C04639332-8016
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900082401
Coding: 0062424
VCID: 224BCAD5FD9A6F31584-8077
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 E HW: 4E0 907 383 E
Component: Anhaenger H14 0080
Revision: 2A002001 Serial number: 00000109325043
Coding: 0200000000000000
Shop #: WSC 95982 999 54568
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J8Y41JG
Coding: 1021201
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H28 0290
Revision: --H28001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7E4ED4FDE6941A28-8039
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD04.02.09--H28001001A0097ÿ
Subsystem 4 - Serial number: 1A0097ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003863046-----
Coding: 0003599
VCID: 2643D6C591B2931134C-8073
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE16_SKB09H10 0200
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE16_SKB09H10 0200
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100662172
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 A HW: 4L0 919 283 A
Component: Parkhilfe 8-Kan H02 0400
Revision: 00H02000 Serial number: 13630833002702
Coding: 0221246
VCID: 285FD8FD9BA68561060-807D
1 Fault Found:
01544 - Indicator Lamp for Parking-Aid (K136)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 6
Reset counter: 40
Mileage: 109425 km
Time Indication: 0
Date: 2015.03.01
Time: 12:59:10
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005079076
Coding: 0010900
End-------------------------(Elapsed Time: 03:18)--------------------------
</pre></body></html>
Parking Aid Button (E266)
¤ Only with 8-channel parking aid
¤ With parking aid switch illumination (L117)
¤ With integrated parking aid indicator lamp (K136)
attach removal for switch for replacement. AND LIGHT BULB.
Q7 Instrument Cluster Button Unit.pdf
P2047 AND 2049 IS SAME CODE CHECK IAW ATTACHMENT
Q7- Reduction Agent Injector, P2049.pdf
P024A P022A,B,C ARE SAME CODES CHECK IAW WITH ATTACHMENT
Q7 P022B p022a P022C P024A.pdf
Q7 Charge Air Cooler Bypass Cont.pdf
READ Charge Air Cooler Bypass Control Unit (J865
AIR BYPASS .pdf
HOPE THIS HELPS
Can someone recommend a place to purchase a new or second hand one, other then the dealer. I understand they are expensive and dealer prices would be my last resort. I live in Canada, would prefer to purchase one here.
Hey there! I am looking to buy this car from someone in New Brunswick......what are your opinions on it? Was it a decent rig?
Thanks!
Mark
