Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Buying used Q7, what should I lookout for
Old Jun 20, 2012 | 07:34 AM
desibeli's Avatar
Default Buying used Q7, what should I lookout for
New here, and new to Audi. I'm looking to buy a used 2007 Q7 (4.2).
  1. Are there any particular issues I should look out?
  2. Any special tests or inspections I should do?
  3. I have VCDS, anything special I should read or monitor while test driving?
Any help would be much appreciated, wife is worried about buying a used car, and in particular the 2007 Q7 after having read Consumer Reports rating on it.
Old Jun 20, 2012 | 08:48 AM
iNfiNkC's Avatar
why not get a 2008?
Old Jun 20, 2012 | 10:26 AM
Jusforfun's Avatar
Old Jun 20, 2012 | 01:12 PM
desibeli's Avatar
2008 seems to be $10000 more or come with 30000 miles more. Is there a big difference between the 2007 and 2008?
Old Jun 20, 2012 | 01:21 PM
weth's Avatar
There are a lot of drain and water leak problems with the '07 model that was corrected in 2008. There is a TSB
Old Jun 20, 2012 | 01:41 PM
desibeli's Avatar
Would it be normal that this have been repaired under warranty in the 2007 Q7 by now?
Can I somehow inspect it and see if it is still a problem with this particular car?
Speaking of TSB's is there a place where I can get a list of all the TSB's?
Sorry for the many questions; first tim buying a used car :-)
Old Jun 20, 2012 | 03:52 PM
Jusforfun's Avatar
View or download the spreadsheet. TSBs have been listed on their own sheet. There may be some more out there if anyone cares to add them.
Some TSBs are only performed on a fail basis so your car may not have them. What if you find a 2007 that has been garaged and never had a sunroof drain or frame problem?
You can ask any service dept for the history if you have the VIN.
To inspect pull/pop off the dash ends where the fuses are and look for rust on the pillars. Open the panel in the rear right and same thing, look for evidence of water.
Find out if any of the door locks have been replaced. Find out if it had any dead battery issues (same thing).
Most 07s will be on a new battery by now anyway. Oddly my own 06 production is still on its first battery though its probably tempting fate to say that!
As you say most 07 problems have been sorted by now. Of late we have not had too many reports on them. If you are handy with excel you should be able to see when faults peaked and which ones.
Old Jul 22, 2012 | 07:37 AM
ercstar's Avatar
Check the brakes, then the brakes, then the brakes and lastly, the brakes.
Make sure the rotors are cool enough to touch and run your finger over the shiny steel exposed edge. If you feel a small lip or feel any groves in the rotor, thats a point to reduce the price.
Your new Q7 is a heavy car and those brakes need to be 100% otherwise your safety is compromised.
Regalflyer
Q5/SQ5 MKI (8R) Discussion
Jan 12, 2017 07:33 AM
Igoboe
Q7 MK 1 Discussion
Sep 14, 2014 06:04 PM
Fez2013
Q7 MK 1 Discussion
23
Dec 4, 2013 07:11 PM
scotty11
Audi Original "S" Cars
May 28, 2006 05:27 PM
PleaseStopMe
16
Feb 8, 2002 05:32 PM
