Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Dension / Device Error Missing Answer for Notification 0x413
Old Feb 9, 2008 | 10:07 PM
fish1001's Avatar
New Member
Default Dension / Device Error Missing Answer for Notification 0x413
Dear all,
Has anybody experienced such problem with the Dension gateway 500. This message comes up after a while on the front screen. Music continues to play but would not allow to access the menu.
After switch off and quite some rest, it will restart as normal until suddenly this error message may appear again.
This happened with software 2.02. I upgraded to 2.08 and it still happens.
I am grateful for any advise.
Thanks,
Fish1001
Old Feb 10, 2008 | 04:03 AM
RAD2's Avatar
Default Did you post/open a ticket at dension support?
I have not had that issue, my dension GW 500 was installed in Dec 2007.<ul><li><a href="http://support.dension.com">http://support.dension.com</a</li></ul>
Old Feb 10, 2008 | 04:57 AM
fish1001's Avatar
New Member
Default Re: Did you post/open a ticket at dension support?
Yes, this was done but no solution so far could be provided by them hence I ask if anyone had this problem and knows how to solve.
Old Feb 10, 2008 | 04:59 AM
fish1001's Avatar
New Member
Yes, this was done. They have answered without knowing the problem and no solution, hence my request if anybody faced same problem.
Tks,
Fish1001
Old Feb 10, 2008 | 08:02 AM
RAD2's Avatar
Default Try navplus if you haven't yet
Also post at the A6C6 and A8D3 forum since they have MMI and many owners have dension GW 500.
Good luck<ul><li><a href="http://www.navplus.us">http://www.navplus.us</a</li></ul>
Old Feb 11, 2008 | 09:35 AM
pauln's Avatar
New Member
Default Re: Dension / Device Error
i had that myself i was told to try the reset button i had to do this about 3 or 4 times then it worked it has been fine since then.
Old Feb 14, 2008 | 10:23 AM
RAD2's Avatar
Default I did start a post at navplus in the Audi MMI section
first reply states possible module vs fiber optic problem<ul><li><a href="http://www.navplus.us">http://www.navplus.us</a</li></ul>
Old Feb 14, 2008 | 03:47 PM
RAD2's Avatar
Default Hard disk
Are you using a hard disk full of MP3's.
Old Feb 16, 2008 | 07:45 AM
fish1001's Avatar
New Member
Dear Pauln,
Great, thanks, I shall try that. I am using the Ipod and no harddisk.
Thanks,
Fish1001
Old Nov 3, 2008 | 06:37 AM
RAD2's Avatar
Default Problem will be solved when you upgrade to 2.15
<ul><li><a href="http://support.dension.com/support-center/index.php?x=&amp;mod_id=2&amp;id=110">http://support.dension.com/support-center/index.php?x=&amp;mod_id=2&amp;id=110</a</li></ul>
