Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
ERROR CODE EPC
Old Mar 17, 2022 | 05:57 PM
Jaymil's Avatar
Default ERROR CODE EPC
Supposed to be in reference to throttle position sensor. Anyone familiar with what kind of project replacing this would be?
Mine is a 2007 S/LINE 4.2 FSI.
Old Mar 17, 2022 | 08:37 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Sounds like you don't yet own a VAG (Volkswagon Auto Group) compatible scantool, which will show you ALL the trouble codes stored by the car, which can be significant, and lead you to the root cause issue. If you don't really DIY, get an OBD-Eleven basic module...it's cheap and works via smartphone interface. If you do DIY and want to be able to really fix things, pick up the VCDS from Ross-Tech...you won't regret buying it, only that you waited so long to get one.
Honestly, that code can get thrown for myriad reasons, one of which is simply that your battery is in a low state of charge, and low battery states occur because they are just simply old, or maybe the battery got swapped but wasn't programmed/coded into the car, or more likely because you've got bad door handle sensors that are slowly draining it 24/7, 365 days a year, just like every other Q7 ever made.
You really won't have a clue about what to do unless you scan the car fully with a compatible diagnostic scantool to see what's really going on beneath the surface.
Old Mar 17, 2022 | 09:17 PM
Jaymil's Avatar
Thanks for the heads up. I'll invest in the diagnostic tool and see what's up.
spinny201
35
Nov 19, 2022 05:54 PM
noffas
Apr 23, 2017 09:15 AM
noffas
Apr 23, 2017 08:37 AM
A4TURBO2 // TMK
Oct 28, 2003 12:35 PM
shaneS4
20
Jan 31, 2003 12:22 AM
