Ford vs. Audi
Am I missing something? How can Ford's V8 have better MPG than Audi's V6?
Don't believe all you read.
Arrie
From Ford:
Fuel economy also is aided by engineering a lightweight powertrain. The engine, as shipped, weighs just 430 pounds. This represents a weight savings of more than 20 percent versus the previous 5.0-liter offering. Lower mass can be attributed to the aluminum block and heads, the lightweight composite intake manifold, composite cam covers and hollow camshafts.
http://www.autoguide.com/auto-news/2...-liter-v8.html
Don't confuse highway MPG with stop and go MPG. The 26 highway rating is a result of higher gearing in the Mustang, possible because of lower curb weight and rolling resistance. The Q7 has more than 6000 lbs to push compared to a Stang with about 3600 lbs. The Q7 has the AWD frictional losses and has much more frontal area causing more wind resistance.
If you compare the city MPG ratings, they are much closer or even better with the V6 Q7.
I get about the same city MPG between my 3.6 Q7 and 6.0 liter Corvette. But on the highway, the Corvette barely turns 1500 rpms to do 70 mph. I get about 25 highway on that 400 hp 3300 lb car.
