Fueling w/Diesel
Regarding nav. Yes I have it but getting diesel is not the problem, the problem I am having is the nozzel.
My question is, Has anyone else had this problem, if not, there is something wrong with my car.
Thanks Again
Surt
Thanks Again
Surt
Just returned from a trip and had one that worked (exon)and one that didn't (Hess).
It could be that the smaller one that does not work is an older style. However, we have found our success is about 50/50 on getting the proper one.
My question, does anyone else have this problem and if so how do you handle it.
If I am the only one, then there is a defect in my filler pipe. However, the dealer says there is no problem there.
Thanks
Surt
The fuel filler door has a flap that is held in place by 2 or 3 locking metal rollers. If a nozzle of the expected diameter is inserted, it pushes aside the metal rollers and the flap moves out of place and allows the nozzle to be fully inserted.
If you try to insert a nozzle of a smaller diameter - the rollers are not pushed back and they continue to hold the blocking flap in place. That prevents the nozzle from being properly inserted.
I believe this has been put there to prevent someone accidentally filling gasolene into the diesel tank (gas nozzles are of a smaller diameter). I encountered this problem in Wyoming - one pump was clearly marked as diesel but had a gas nozzle and I was unable to use it.
There is no way to "handle" it - you just have to find a pump that has the nozzle of the right diameter. Like I said - this has happened to me only once and has not been an issue. Which state are you in?
I have read on some forums that at some stations, particularly stations in Wisconsin, a gas pump nozzle is used on the diesel line on occasion. This would definitely cause the issue described on this thread.
For those who are new to using a vehicle that requires diesel fuel, here are a couple of things to keep in mind.
While using #1 fuel in the summer will not cause any real problems, you may see a drop in MPG.
In northern climates during the winter, you will want to fuel with what some stations call a “winter blend”. This is usually a blend of #1 and #2 fuels.
If you fill with #2 fuel and drive into a region where temps are below freezing, you may find yourself stranded as the fuel gels up in the fuel line and\or fuel filter.
Just like with gasoline, not all fuel stations have quality product.
If a station provides diesel but there are fewer customers, be careful fueling in late fall and early winter as the station may not have cycled through the summer fuel before the cold weather hits.
I have driven diesels for a number of years, previously a 1996 VW Passat Tdi, and I have never had my fuel gel up. Plan ahead and pay attention to what you are putting in the tank and you should not have any problems with gelling.
