Heater problem
It just blows cold
Have found out there is a steeper motor for temperature adjustment 1 for each side ,does anyone know where the drivers 1 is located on the heater housing and the replacment procedure
Thanks
The early Q7's had Bosch stepper motors (I believe) and were notorious for failing. I had ALL of mine replaced under warranty. Other symptoms included a click-click, click-click sound coming from behind the dash when you first started the car. Especially when cold. Apparently Audi switched vendors sometime after the '07 model year.
