Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Help!! Climate control recode???
Old Nov 25, 2019 | 10:24 AM
Jack123's Avatar
Default Help!! Climate control recode???
Hi
I have a 2007 Q7 and have recently purchased a second hand climate control unit as the numbers on my old units display I could barely read
anyway so I fitted it and now it just says off and all the buttons do nothing on it apart from front demist windscreen and heated rear window button
the rear climate control also says off!
does it need recoding via VCDS if so some guidance on how would be appreciated I’ve used it before so kind of know a bit about it but a quick walkthrough but be very appreciated I took pictures of the previous sticker on my original unit and the second hand one and it doesn’t say any codes on there to input
thanks
Old Nov 26, 2019 | 11:26 PM
Built4Sin's Avatar
Originally Posted by Jack123
Hi
thanks
A lot of the electronics are component protected “CP”. So you’re going to have to find a dealer, and have them code it correctly. If you’re in Europe, you could have it removed quite easily.
Old Nov 27, 2019 | 04:58 AM
Dudeness30's Avatar
Hey Jack where are you located, maybe someone here knows a good place in your area.
Clay Atchley
Q5/SQ5 MKI (8R) Discussion
10
Jan 17, 2025 05:08 PM
brocky
A4 (B8 Platform) Discussion
Aug 17, 2019 06:03 AM
Josh S4
Feb 4, 2004 06:19 PM
buster3845
Oct 3, 2003 09:50 AM
dinger
Sep 11, 2002 01:31 PM
