Replace engine or move on?
Recently it started smoking under the hood just a couple miles from home (no indicator lights came on), and won’t start. Had it towed to the dealer service shop which they are stating its engine failure!
The worst part is the extended drivetrain warranty (10 yrs/ 120k miles) just ended 2 months ago !!! So now I’m stuck with do I pay for a new engine or move on??
I did reach out to Audi for assistance which the stated they would cover 50% of the costs, this leaves me a $10k bill.
Does this happy often? Should I try reaching out to Volkswagen group? As I’m still kind of upset on the matter being low mileage on a diesel engine and just over the 10 yr timeframe. I’d love any advice on the matter. Thanks!!
When your dealer states "engine failure" exactly what was their diagnosis?
Audi has been known to misrepresent damage and claim that a new engine is needed when it's not. Sometimes the 'Audi approved service' and whats actually needed are two very different things. Works great if you have warranty, not so great if you're paying out of pocket.
Maybe someone else can more familiar with the TDI can chime in but a failed chain or tensioner throw a bunch of codes and trigger the CEL. Seems crazy to pull the engine if they're not certain it's the cam chain.
Did the 'smoke' smell like diesel fumes/raw diesel exhaust? It's not uncommon to have injector seals go bad, or an EGR Cooler's connection pipe leak, both of which vent raw exhaust/smoke/ash into the engine bay. Diesel fuel has a very high flash point, so you normally aren't going to see engine fires on a TDI motor, even if a fuel line is leaking. If the smoke was thick/scary/pervasive, then it is more likely an oil leak that got onto the exhaust manifold/pipe. You definitely want/need to know exactly what the dealer tech documented and how they ascertained it requires a new motor, and they shouldn't be trying to keep that info from you.
With zero engine warnings, and on such a low mileage TDI, I would surmise the 'stealership' is likely trying to do just that...steal from you.
You should verify any recent work records done by the Audi dealer under warranty though, as all that work comes with a guarantee/limited warranty period attached to it, etc., and so if there is actually a major engine problem when you've been doing all required services via the Audi dealer, then the dealer is the most likely suspect.
As stated, you need to understand how they arrived at this diagnosis that the engine must be replaced. Paying a well qualified indie mechanic to go over your car, and/or interpret what the Audi dealership is telling you is wrong is probably the best $100 you'll ever spend.
That said, and it should be noted this car is famous for giving loud, obnoxious, bright, flashing warnings on the dashboard that will make you believe a UFO just landed on your car, or that it is really about to explode if you don't turn off the engine immediately; I've seen those warning lights...difficult to forget that kind of drama.
In the 'worst possible case' scenario, where the engine has somehow died an unimaginably untimely death via a catastrophic failure, and with no warning ;provided whatsoever, then the corporate Audi offer of you paying $10k total for a brand new TDI engine to be swapped in is actually a steal of a deal, since they normally charge $5k just to drop the engine out of the car to do repairs on it, etc.
As for me, I don't trust any Audi service department, as all I've run into at multiple dealerships is crooks trying to line their pockets and boost revenues by lying to me about our cars, over and over again, and so I will never go back to an Audi dealership, not ever. They definitely count on their owners not knowing anything about the cars they drive, which makes said owners easy targets for both deception and outright fraud.
I'd definitely be requesting full disclosure on what diagnostic procedures were followed, and the results of scans/diagnostics, etc. to assess your engine as being 'toast', and since you don't know cars, you need your own 'expert' to independently assess and verify the dealer's diagnosis, look at your service history records for this car, and tell you what's really going on.
That's super-frustrating they've put you in this position, but I'm really glad you did appeal the dealer's repair assessment cost to the corporate team at Audi, so you've got options, and possibly much, much better options once you get the diagnosis verified independently.
The Q7 is running now and I've been super happy with it as this is my first Audi.
Yeah, never trust an Audi dealership to diagnose or repair your car is the moral of this story; so much grief can be avoided by not taking these cars to an Audi dealership where their main goal is to exploit you. I'm so glad to hear you bought it and identified the real underlying causes (thermostat leak/alternator seized, etc) via normal mechanical troubleshooting, and best of all you likely paid very little for a well maintained Q7, although you'll want certainly want to do your homework on this car as there's a learning curve; all driveline fluids that need to be changed that Audi left off the service charts, etc., etc., and known issues with 4L platform in general relating to clogged drains and water leaks, parasitic battery drains from door handle sensors, etc., etc.
Great cars and not terribly difficult to keep up once you know what's what.
