Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
replacing the auto shift knob instructions???
Old Dec 1, 2010 | 12:14 PM
  #11
arp2nr's Avatar
The internal working are: when you push the button on the shifter it pulls up the lever in the transmition. So some how you will have to make something that you will have to pull up. post pics when it is all done.
Originally Posted by Poncherelly
Great information, I'm thinking about making a brushed aluminum shifter **** for my Q5 and needed this informaiotn to pull it off. Anyone have information on the inner working of the ****? Since I'm making this myself, I'm a little paranoid to disasemble my stock shifter incase I want to switch back.
Old Mar 22, 2012 | 03:04 AM
  #12
Moisted's Avatar
Originally Posted by arp2nr
here are the directins to remove shifter I did it 30 min
1>Unclip mounting frame for selector lever boot -1- from center console and lift it upward and off -arrows-.
2>Secure lock button in pulled-out position using a cable tie -arrow- as shown in illustration
3> Flip selector lever boot -1- upward and over selector lever handle -2-.
–Open clamp -arrow- and pull off selector lever handle together with selector lever boot, without touching lock button.
4>Sparating selector lever boot from selector lever handle
4a> Bind spring tabs -1- of selector lever handle together
with a cable tie -3-, as shown in the illustration.
4b> Push sleeve -2- of selector lever boot over retaining
tabs on spring tabs -arrow-.
4c> Remove cable tie and remove sleeve with selector lever
boot from selector lever.
Sorry but I'm having a hard time following these instructions. Very strange way of using punctuations, and the numbers in the text don't match the pictures. Is -1- supposed to refer to A in the pic, and -2- to B....
Confused...
Old Mar 22, 2012 | 06:35 AM
  #13
arp2nr's Avatar
Confused...
here are the instructions changes to the alphabet referances:
1>Unclip mounting frame for selector lever boot -A- from center console and lift it upward and off -arrows-.
3> Flip selector lever boot -A- upward and over selector lever handle -C-.
4a> Bind spring tabs -A- of selector lever handle together
with a cable tie -B-, as shown in the illustration.
4b> Push sleeve -C- of selector lever boot over retaining
Old Jun 10, 2012 | 11:33 AM
  #14
johnnylea_09's Avatar
Default Just Installed S3 ****....
Took noted on your instructions and now I have a new **** looks great. Only if'y part was twisting the plastic eyelet from normal right thumb button press, all the 90 degrees facing front. From there I was able to install the new **** works great!
Thanks Bud!
Johnny
Old Aug 9, 2015 | 10:05 AM
  #15
asian_A7's Avatar
Would this be the same step for the A7?
Old Nov 25, 2020 | 06:06 PM
  #16
Johnny Saldivar's Avatar
Default 05 Audi A4 B6 auto shift **** install
Hello I’m having trouble installing the auto shift ****. So far I’ve seen most videos and once I push down the ****, pull the thumb button back, push down the **** all the way and that’s where it goes bad. I release the thumb button and try to shift to a lower gear it gets pushed in all the way and it will not shift to lower gear.
oohay32408
Jan 11, 2012 12:03 PM
downunder
Jul 7, 2006 12:16 AM
BASELINE
Dec 9, 2003 12:54 PM
trojansruleucla
Jun 27, 2002 03:31 AM
