Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Is the sunroof supposed to rattle when it is freezing outside?
Old Jan 22, 2008 | 11:31 AM
AutoUnionQ7's Avatar
Default Is the sunroof supposed to rattle when it is freezing outside?
Couple weeks ago, it was around +7F at night, and as it was being driven, I noticed that the sunroof was being noisy for a couple seconds, and then it stops. and then its again.
Old Jan 22, 2008 | 11:43 AM
BozemanQ7's Avatar
New Member
Default Re: Is the sunroof supposed to rattle when it is freezing outside?
I was out in my loaner last night while it was -23F and there was no rattle except from my teeth.
Old Jan 22, 2008 | 12:36 PM
I guess the dealer will be looking at that at the 5k service...
Old Jan 22, 2008 | 02:27 PM
wbwynn's Avatar
Member
Default I have noticed this too, but
I took delivery on 12/29, so I don't have any warm weather experience. I have noticed a creaking sound when I go over rough bumps in the road; it sounds like it is coming from the roof area. Could it be the panoramic roof is not sealing tight in the cold weather. I will also have this checked at 5k service, but I'm only at 800 now. Please let me know what you discover on this issue. Thx
Old Jan 22, 2008 | 02:28 PM
floormat's Avatar
Default Mine did that the other day
but only because there was some moisture (snow) that had melted and then frozen to the roof. After it sat in the garage overnight it was fine.
Old Jan 22, 2008 | 03:08 PM
that's what I mean. When there is ice on top of it.
Old Jan 22, 2008 | 03:09 PM
nope problem. We have 1500 miles to go until the service...
Old Jan 22, 2008 | 03:17 PM
Trouties's Avatar
New Member
Mine was noisy when the 70 MPH Santa Ana winds hit last week Calif
Old Jan 22, 2008 | 06:31 PM
Q7Q7Q7's Avatar
I've had the car through the heat and cold Canadian winter. The rattle (which I describe as more of a creak) comes from moisture that freezes at the front of the panorama window (when it is open, feel the "felt" seal and it will be wet). I found that when the weather warmed up, I wiped it with a rag and then when it froze up again, it was fine. I don't think that there's much that the dealer will do. The roof will not leak, so there's no worry there.
Old Jan 23, 2008 | 01:20 AM
finally! A fix to this problem! Thanks!
