Hitch maximum ball rise
Now I was at the dealer to make the deal, but first wanted to check the trailer hitched on and discovered the trailer tongue is 23 1/2" from the ground (lower part of the tongue) when leveled whilst the hitch receiver is 16 1/4" from the ground (upper part). Apparently the standard Audi ball has a 2" rise, but for this trailer I would need 7" it seems. Then we looked at other brands and their tongue height at level was about the same. The lowest we could find was 19 3/4 which would still demand a 3 1/2" rise. furthermore, hooking it on showed a 1 1/2" sag so fully packed I expect 2" meaning the figures above should be added 2", am I correct?
I already concluded the standard Audi hitch will not work, but mounting a 7" rise, would that even be possible?
Makes me wonder how other people handled this since I've seen examples on this forum of people towing double ax trailers of this size with their Q7, can anybody help?
thanks beforehand!
My Lance trailer does ride lower to the ground than many other dual-axle 21' trailers. I had measured about 21" at one point. I have the Audi standard ball set up with a rise, and then got the Curt hitch ball with 2" rise shank:
That setup does a great job for my trailer. I may be just a hair nose down, but pretty darn close to level. HOWEVER, I have the air suspension, so I do not get significant sag. Our unweighted car receiver heights are similar. So, yes, if you're tongue is 2.5" higher than mine and expect 1.5" sag, you'll need another 4" more than me... It will look odd, but I don't see why you couldn't put a 7" rising hitch. I would do one of the adjustable kinds so you could adapt to anything you might tow. Have the shank drilled so you can have the ball closer to the rear bumper to be within Audi spec. The biggest issue you may run into is whether you can still open the trunk with the trailer hitched up depending on how far forward the hitch jack controller is.
Be sure that the dealer actually weighs the tongue weight for that trailer. My Lance trailer tongue weight was WAY heavier in real life than the brochure had stated. I removed the wet-cell batteries from the front and replaced them with a dry battery installed inside behind the axle. I travel with only one propane tank and have to be careful packing in order to keep the tongue weight just barely at Audi spec.
I know factory figures are always the optimal ones and sales guys just tell you whatever you want to hear. It took me already quite some persuasion for the sales guy to help me out, looking for a ball mount and hooking the trailer to my car instead of just chattering about the great features and saying "yeah, you're good" when asking about the weights
Anyway, thanks for your feedback, I decided to order an adjustable one with weight scale included, that will immediately help me with the tongue weight problem you mention.
I ordered this one (8" drop/rise):
thanks beforehand!
hardware.
I do get some drop and trailer won't be 100% level but I think that would be better than having the trailer level and such a high ball receiver. I'm not a towing expert (though an Engineer). The amount of forward/backward force at such a distance high will create a much larger torque and will impact stability of the vehicle a lot more than not having the trailer level. Think of it, if the trailer is not 100% level the load on the hitch might increase by a small amount but if you use such a high extension (say the distance is 40% more to the pin) it creates 40% more torque. It works like a pry bar with the force of the trailer behind the end of the pry bar when you pull or stop.
I now ordered the 3503 - 2" Alumistinger ball mount which gives a 1" rise, after all the research I discovered that this is the only ball mount that comes close to the 6.2" that Audi demands since I understood that the official Audi mount (from Curt) has even 9"? I could potentially add an additional 2" rise ball to level. However, now I discovered you cannot add a sway bar to that ball mount so I will have to do without. Unless someone would tell me that I really need one? Then I switch to the Audi (Curt) ball mount and add a sway bar.
Especially with a single-axle trailer and the fact that you're planning long distances, I would feel better with a sway controller. Be sure to also weigh your tongue weight once you are set up and loaded to be sure that your load distribution isn't making the tongue too light.
So I reviewed it all again and since the hitch is too small for the part suggested (see topic: https://www.audiworld.com/forums/q7-...acket-2975091/) and an aluminum one (which make welding complicated), I found a curt 3/4 rise with sway tab https://www.curtmfg.com/part/45820 I will use a 2" rise ball to compensate the sag (https://www.curtmfg.com/part/40034).
I also ordered the betterWeigh mobile scale (https://www.curtmfg.com/towing-acces.../betterweigh); it appears to work well, I'm curious
I just ran out and took a tongue weight and it came to 460lbs with this one below. I have two 20lb tanks and one battery so that seems about right because my trailer is 360lbs dry with nothing in it.
was to drill another 5/8" hole for the pin closer to the ball. This way the receiver sits further into the receiver and is within the recommended distance.
BTW, one thing I learned is that trailers might weigh different thans spec, e.g. ours is supposed to be 400lb dry at hitch but I just weighed it today and it's over 515lb.
