Homelink
Homelink
Hi-
Please let me know if I'm missing something but it appears that my Homelink linked to my garage door opener only works if the ignition is on? Every time I park my Q7 back into my garage, I turn off the ignition but then I am unable to use my Homelink to close my garage door. I have to remember to press the Homelink first before turning off the car. Something I have to remember to do as this is different from my previous car (Homelink worked without the ignition). Thanks!
Ultimate Keyboard Warrior
Hi-
I am final remembering to hitting the garage door button before I shut off the car. My last two cars sensed whether the key fob was in range of the car or not. One car I had would open the garage door even if the car was off and the key was nowhere in the area. I parked that car in the driveway and did not thing that was safe.
Thanks. Since it's not natural for me to close the garage door while the car is still running, I will use the garage door remote opener. This defeats the purpose of Homelink but at least I can close the garage door in the winter while I'm still in the car.
Hi-
Homelink only works with the ignition on. This is a safety feature and if homelink was always hot, I would not use it. It is designed to open your garage when you come home and close it when you leave. If the homelink is always hot, and the car is parked in your driveway, all someone has to do is break a window, press the homelink and has direct access to your house.
You don't have a wall mounted button to open/close?
Hi I do have a wall mounted. It's just something I'm used to especially during the winter here in NY with 3 kids. I rather drive into my garage, turn off ignition, close the garage door and then my family gets out of car so they don't get too cold. I know, it's a peculiar but just habit!
I get the idea of killing power to it if the car is parked outside (but then you should lock your door to the house anyways if you're worried about people getting into your garage and then your house), but it's a PITA if you park inside all the time. Too bad they didn't offer the option to toggle the operation of power (or keep it powered for a minute afterwards -- that would be best!)
