Newcomer
Old Jun 7, 2005 | 12:43 PM
01A4TQMS's Avatar
Default Newcomer
Hello all. Just got an 2001 A4 1.8T about a month ago. Living in Boulder right now, and would just like to know some good mods for the ride. So far I have done a Neuspeed SS kit, MOMO shift **** (Fri), and the one-tough up mod for the rear windows. Going to get a Dahlback chip and BPV installed on Friday at AutoSport Werks.
Old Jun 7, 2005 | 12:58 PM
gietl's Avatar
Default Re: Newcomer
Daaaaaaaaaaaaaaym, don't waste any time do ya? After all that you definitley need to make sure the suspension is tight enough. Having a car that can go fast isn't much good if it doesn't handle well.
I personally would have gone susp before chip, but if money isn't an issue right now just keep going. There are a few different routes to go with susp so i would do a search (especially in the B5 A4 forums) otherwise I am sure some folks will shim in.
You could also ask the folks at ASW while you are there about suspension options.
Old Jun 7, 2005 | 01:02 PM
01A4TQMS's Avatar
Default Sport package
I have the sport package. Is that good enough for now?
Old Jun 7, 2005 | 01:11 PM
de (-eeez_nutz)'s Avatar
AudiWorld Expert
Ask ASW if they can enable remote windows and auto door locks for you, too
Old Jun 7, 2005 | 01:14 PM
LaserAvantS4's Avatar
ASW carries dahlback now?
Old Jun 7, 2005 | 01:16 PM
01A4TQMS's Avatar
Yea, and I was told they stopped carrying APR.
01A4TQMS's Avatar
Default How do they do that.
And do I need a new remote?
Old Jun 7, 2005 | 01:21 PM
AudiWorld Expert
Default With Vag-Com, and you use the same remote.
To work the remote windows after recoding, you just hold the unlock button down on your fob to roll the windows down (all 4), and hold lock to roll up.
The Auto door lock recoding will automagically lock your doors once you hit 15mph, and unlock when you remove the key from the ignition.
de<ul><li><a href="https://www.audiworld.com/tech/elec13.shtml">Tech article</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 7, 2005 | 01:28 PM
gietl's Avatar
Default Re: Sport package
Sport package is a good start, you will probably find that you may even want some more drop and a stiffer setup, but yeah, it's probably fine.
Old Jun 7, 2005 | 01:29 PM
silverA4TQM's Avatar
Junior Member
Don't pay for that though, someone here will do it for you I am sure
