Alignment needed
With ODIS lowering every drive select mode will be lowered the same amount. With the CETE setup you can select an amount of lowering individually for each main drive select mode. This means you have the full range of the air suspension at your disposal along with the ability to lower some drive select modes more than others and the CETE setup will remember your settings without needing your phone on you or in the car. It's definitely more versatile plus you can change the lowering amount with a few clicks if you want to change it versus having to redo the whole ODIS process to change the amount you have the car lowered. More information available here:
Module Package | CETE Audi A7, S7, RS7 C8 Air Suspension Lowering <-Click Link for More Information
If you have any questions on this or any CETE product don't hesitate to let me know here or via email: contact@europrice.us
Cheers,
Cheers,
Thank you so much for the info. CETE it will be.
