RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Fault Code P0431
Old Aug 16, 2007 | 09:44 AM
Ubercar's Avatar
New Member
Default Fault Code P0431
I find that about once per month I get the check engine light and the following emission related fault code - P0431 Warm Up Catalyst - Efficiency Below Threshold. I assume that this may be related to the after-market cats on my Milltek down pipes and that the code is more of a nuisance than a real concern (until I am due for the State emissions test, perhaps). Anyone out there with similar experiences or greater wisdom, please chime in.
Old Aug 16, 2007 | 10:00 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default Yep - the ECU looks at the O2 sensor before and after - It is expecting to see a flat line
on the sensor after the cat and fluctuation on the one before - if the two track each other then it suspects a failing cat.
APR and other tuners can turn this off with their flash on the other Audis
hanshy5
May 25, 2011 06:04 AM
beejohn
Feb 18, 2008 03:31 PM
geauxfaster
Aug 17, 2005 06:51 AM
sacaudi
Mar 9, 2005 10:34 AM
VA_Esfour
Jan 21, 2005 10:20 PM
