S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Engine startup rattle problem. Possible resolution....
Old 08-01-2007, 07:10 AM
BrianG's Avatar
Default Engine startup rattle problem. Possible resolution....
I've complained about an engine rattle that happens about 50% of the time for just a couple seconds immediately after startup. I had chalked it up to the timing chain hydraulic tensioners and the TSB that describes that noise, but as the sound continued to get worse and more annoying, I pushed my dealer harder to find a solution.
They heard the sound once on a visit about 9 months ago, but couldn't reporduce it, so they did nothing. The next time I had it in, they said they never heard it. Finally I pushed them to get Audi involved. The service manager contacted Audi's regional tech rep and set up an appointment for him to look at my car.
I was there with them when the service manager, the dealer's best tech, and the Audi regional tech rep started the car to listen for the noise. Luckily, the noise happened that time and the tech rep immediately said that the noise is coming from the intake manifold. This was the first time I was outside the car listening when someone else started it, so it was pretty clear to me, also, that the noise had a hollow, almost "plastic" echo that clearly was coming from the plastic manifold housing.
It turns out that the sound is the flap inside the manifold that alters the runner length to flatten the engine's torque curve. For some reason the flap is slapping open and shut a couple times when it shouldn't. They replaced the vacuum piston that contols the flap, but that didn't solve the problem. They measured the vacuum and that is fine, too. The next step is to replace the entire manifold housing with flap mechanism. I'm waiting to hear by the end of the week if that has solved the problem. Keep your fingers crossed for me.
I'll post the results next week.
Old 08-01-2007, 07:55 AM
AudiWorld Expert
Sia Bani's Avatar
Wow, interesting.
Old 08-01-2007, 07:59 AM
bhvrdr's Avatar
Thanks for posting that. Interesting indeed.
Old 08-01-2007, 08:04 AM
ESFO's Avatar
Very nice! Thank you for being persistent with that.
Old 08-01-2007, 08:31 AM
Rob4.2's Avatar
BrianG for President!!!
Old 08-01-2007, 08:56 AM
defconfour's Avatar
Thanks for sharing - it might be good to know for some us in the future
Old 08-01-2007, 08:57 AM
Corrado79's Avatar
Can you describe the rattle some more? I have a noise at startup, but sounds more like a screech
Old 08-01-2007, 10:01 AM
Banned
DrGP's Avatar
Default What would be the ramifcations of not doing anything about it?
Does the car run well otherwise? I know we can all be somewhat **** about the little noises we hear in our cars.
Old 08-01-2007, 12:20 PM
Tal-Yvan's Avatar
Default Interesting, but for me that knocking/rattle noise is an indicator of low oil..
Usually after I get that noise at startup, the oild light comes up.. like 200 mi after, 1qt of oild and noise dissapears (sp?)
Old 08-01-2007, 04:18 PM
BrianG's Avatar
I tried topping off the oil months ago and it had no effect on my problem. Different problems?
Quick Reply: Engine startup rattle problem. Possible resolution....
