Error Free LEDs for your Audi - Interior LEDs - Reverse + Much more! Ships FREE!!
#31
Audiworld Basic Sponsor
Insane bright Fogs without blinding glare
-more light on sides
-more light down the road
-perfect for foggy conditions when your low beams are trapped - your fogs will take over and help you see:
LED Headlight/Fog CREE LED Bulb with Ballast - 9000 total lumens | deAutoLED
Choose your fog model on the drop down - these work in all Audi Model!
Attachment 105124
Attachment 105125
Attachment 105124
Attachment 105125
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
#32
Don't miss out - pick up a set for yourself and see the difference:
LED Headlight or Fog Bulb Kit - Error Free - Plug & Play | deAutoLED
More light
Error Free
Plug & Play
Won't cause blinding glare
NO radio interference
Shines past your headlights and helps more during bad weather, cornering, and on darker roads!
#33
Thanks for the support - email us at anytime if you need any help finding the right LED for your car:
Support@deAutoLED.com
#34
White/Yellow/Halogen/Strobe/Flash plug and play fogs:
Dual Color LED Fog [1 bulb 2 colors] Choose between a Clean White & Hyper 3000k Yellow at anytime | deAutoLED
-Plug and play
-Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
https://www.youtube.com/watch?v=T-fex4DUPSg
3 colors:
-Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
-Clean White 5500k that matches our LED & HID Headlights
-Halogen 4300k that matches OEM
Video cycling quickly through colors AND different strobe/flash features:
https://www.youtube.com/watch?v=bQG0gRKGFk0
INFO:
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
Attachment 104952
Attachment 104953
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Some more fun shots - in the rain:
Attachment 104954
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
Attachment 104955
Attachment 104956
And switch back to clean white:
Attachment 104957
-Plug and play
3 colors:
INFO:
Attachment 104952
Attachment 104953
UPDATED FAQ
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Attachment 104954
Attachment 104955
Attachment 104956
Attachment 104957
#35
No joke very bright hyper yellow 3K Plasma Fogs:
Just Yellow Hyper 3000k Plasma Fog LED Kit | deAutoLED
This 3K hyper-yellow 3K is also available in the switchback white/yellow model:
And solid white:
Attachment 105037
-easy install
-lifetime warranty
-plug and play
And solid white:
Attachment 105037
-easy install
-lifetime warranty
-plug and play
#36
Choose your Fog LEDs
Just yellow Fogs
Just White Fogs
White/yellow with or without strobe:
-ALL you need to know is your bulb type - choose what style you want on this page and then choose the bulb type on drop down menu:
Fog LEDs | deAutoLED
Attachment 105035
Just yellow Fogs
Just White Fogs
Attachment 105035
#37
Find out why we are the go to place!
LEDs for your Audi: Front turns, Low Beam, Fogs, Interior, Reverse and everything else - we have custom LED kits you cannot find anywhere all plug and play error free.
If you cannot find what you need on our website: www.deAutoLED.com - simply email Support@deAutoLED.com for instant help - we have 24/7 customer service and ship daily from the US.
We know many might've had bad experiences with other LEDs and many emails start with "This LED had this issue will your product have the same problems" - the answer is NO - our LEDs are tested in your model to work and look good.
Some examples:
-Error free front turns that are bright and can be seen in direct sun light
-Low beam d3s HID that are bright and clean white that match other LED DRLs
-Fog LEDs that shine wide on road and help and are not a novelty
-Error free plug and play reverse LEDs you cannot find anywhere else that are very bright
-Interior LEDs that are all different style bulbs - we don't just throw 20 194 wedges that look the same like some kits. Each one is designed around your housing
-We customize our LEDs to work with the Audi electronics and why ours are sometimes the only ones that work - working is 1 thing but we then also make sure they are bright and something you want to use.
Thank you
Some examples:
Thank you
#38
#39
#40
