S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
2011 S4 stuck around 5-6 PSI boost
Old Oct 17, 2012 | 12:37 PM
jceven's Avatar
Default 2011 S4 stuck around 5-6 PSI boost
Hey all,
Just noticed the other day that my Boost gauge (AWE tuning vent mount gauge) was only peaking around 5-6 PSI when I have the throttle down to the floor (usually peaks around 12, 13 or so). I thought maybe the gauge is off, but my one grease monkey friend says its not pulling as hard as it used to. I am going to have access to a VAGCOM/VCDS tonight to read block 436 to read the absolute manifold pressure, to make sure there is really a problem. I also noticed I am not hearing the same sort of supercharger whine I was used to.
Assuming I read low boost/pressure in the manifold what steps would you all take next? I am not too familiar with how the bypass/diverter or etc work on the supercharged engine in the B8 S4. I did have to install a boost tap between the throttle body and the supercharger output when I put in the gauge, but that was about a year ago, and things have been solid since then, up until a few days ago when I noticed the issue.
What next steps would you all take if I read low manifold pressure. Was thinking that I could take out the boost tap and return to stock, and re-measure block 436 for the manifold pressure. Although I don't suspect a leak around this boost tap, it will return the car to "stock" config without the boost tap between the supercharger and throttle body intake. If that reads low, then I guess I can take it to the dealer and tell them "the car is not developing the correct amount of boost, please check it out".
A little background, the car was stasis tuned before I bought it in may of 2011, and the stasis work was done by the audi dealer I get maintenance/service from. I don't think this has anything to do with the issue but maybe it does. I wonder if I'd expect a CEL if the car was producing way low boost? There seems to be a lot of voodoo around an ecu reset, but for what its worth, I did disconnect the battery for 10 min, and then rehooked it up, then let it sit, then started the car, and let it sit for a while idling. Same issue after.
Cheers
Old Nov 19, 2012 | 11:11 AM
yourownhero's Avatar
Originally Posted by jceven
Hey all,
Cheers
I would check the tubing on your boost gauge...the tubing is fairly cheap and known to split, or crack due to temperature changes and how long its been on the car. If you call AWE they will send you new tubing free of charge, or can buy 3mm (i think thats the size) tubing on amazon and rerun the tubing or just replaced the split section. If your tubing isnt cracked, then i would take it to audi.
leonpro
1.8T Discussion
Aug 7, 2006 07:54 AM
TTDirk
Mar 31, 2006 10:35 PM
Shep 1.8T
Sep 14, 2005 03:29 PM
alibaba
Mar 21, 2005 01:59 PM
A4 Moda
Dec 16, 2004 06:59 PM
