2012 DSG with NO sports mode?
I often do this to pass and then move the shifter to the right and left in quick succession to drop back to D mode. Note: The car will drop back D mode by itself after about 15 seconds.
We all have Sport function. We all have Manual function.
Manual is selected by moving the shift lever from D to the right. From there you manually shift it by paddling or tapping the shift lever front(up) or back(down). It allows the driver to manually upshift or downshift within the ecu limits. Nothing more occurs within the system.
All our cars have "S" Sport function. Non-ads and non-sd cars have the S on the console. You simply pull back on the shifter (depress the button on the shifter handle). You can use the paddles any time you want. )
If you have ads or sd you select Dynamic, which activates the Sport function. Here to you can use the paddles anytime too.
It'll affect steering, throttle response and shift points on the sd cars and ads cars, with the suspension changed on the ads cars.
Read the manual to take full advantage of this excellent example of a German Sports Sedan. Never speculate. .02
