Fault Codes - what to do
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050
Revision: -------- Serial number: --------------
Coding: 290D1A
Shop #: WSC 06325 000 00000
VCID: 820108BAA49F
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 10688 km
Time Indication: 0
Date: 2011.07.10
Time: 21:31:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4082
Hex Value: 0x0032
Hex Value: 0x02A9
Hex Value: 0x00FF
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01190520100414
Coding: 66102000
VCID: 800502B2AA93
1 Fault Found:
00713 - Centre Left Vent Positioning Motor (V110)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 21
Mileage: 10603 km
Time Indication: 0
Date: 2011.07.09
Time: 15:44:18
Freeze Frame:
Voltage: 13.20 V
Temperature: 32.0°C
Temperature: 30.0°C
Count: 14217
Count: 16440
Bin. Bits: 01000000
Bin. Bits: 10001001
Time: 13.00 s
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000651221
Shop #: WSC 00000 000 00000
VCID: 346D1E622EAB
1 Fault Found:
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 60
Mileage: 10688 km
Time Indication: 0
Date: 2011.07.10
Time: 21:31:55
Freeze Frame:
Voltage: 13.70 V
Count: 57
Speed: 0.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0101
Regardless, should I just clear it and see if it pops up again or should I contact the dealer?
