S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Keyless problem
Old Jul 19, 2012 | 05:16 PM
Dantes's Avatar
Default Keyless problem
Keyless does not work. The open/close button on Remote does not work. It still does not work even replaced the battery. Only the physical key can open/close the door. Anyone comes across on that ?
Old Jul 19, 2012 | 06:45 PM
ezveedub's Avatar
Does the remote led flash when remote buttons are pressed? It should. Also, when using the keyless system, when you touch a door handle to open/lock the doors or use the start button, the led should also flash. This would mean the remote is receiving a signal from the car and sending the authorization signal.
Old Jul 20, 2012 | 10:29 AM
L0U's Avatar
L0U
Mine stopped working for a few days after I used the vag cable on it to tweak a few things. Started working again soon after though.
Old Jul 20, 2012 | 07:40 PM
Dantes's Avatar
Thanks for the tips ! The LED does flash when I press the button on the remote. But it still can't open/lock the door. It seems to me the Central Lock System has some problem (might not the keyless sensor on the door handle) ?
Old Jul 20, 2012 | 07:43 PM
Dantes's Avatar
May I know what is VAG Cable ? What is that cable for ? Please
Old Jun 20, 2019 | 06:33 AM
Yaemish's Avatar
You are right in it not making sense, I seem to remember having the same feeling with my old overhead unit.
Going from that same rusty memory, I think I did a sync of the original OEM to the car. Once you do that, you press the sync button on the back of the overhead unit and again do the car pairing.
cbrown9064
Nov 19, 2006 04:13 PM
supawyde
Jan 26, 2005 01:54 PM
Imola Ghost
Apr 19, 2004 06:02 AM
rocky mtn TT
Nov 30, 2001 09:59 AM
Josh
Jul 22, 1999 06:57 AM
