Locking without the (advanced) key
I leave my vehicles to be washed at a service location and take the key with me.
When I return later, the service is gone and the car is locked.
Unfortunately with Audi's "advanced" key, there doesn't seem to be a way to lock the car without the key! The lock switches on the door are disabled without the key.
Has anyone figured out how to lock to the vehicle without the (advanced) key?
I was told by the dealer that the advance keyfob costs over $300 to replace so it's a good idea not to leave it with anyone.
Edit: I guess it's called the emergency key, not the valet key.
You should be leaving the fob half with them and take the physical key so you can lock the trunk, the GB and the rear seats. Unless of course they're detailing the trunk, then leave it unlocked in the GB.
I know other models do this (Cadillac) but not so for us lowly Audi owners
I guess the idea here is if you accidentally unlock the locked car as your're walking away from a locked car (for example the unlock button is accidentally pressed in your pocket), the computer presumes you meant to lock it, and does it for you. In this scenario it will lock the car regardless of whether the master key is in range or not (I tried it both ways).
Otherwise, if you park the car, shut it off, and get out (for example in your garage), but don't give the computer any indication you wanted to lock it, the computer figures you intended to leave it unlocked.
I guess it's best there is no "always lock the car after x seconds of being parked and closed," to prevent a case where for example you go to the store and the master key fell out of your pocket while in the car, and you don't realize that until you come back to the car and can't get back in.
