S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Lowering and tire wear?
Old Nov 23, 2010 | 06:15 PM
LeadToRome's Avatar
Default Lowering and tire wear?
The title pretty much says it. Approximately how much faster will tires wear say with an inch of drop vs stock and with 2 inches of drop vs. stock? I'm not looking for exact numbers but just a general rule of thumb. There's nothing really wrong with the stock suspension geometry and tires are pretty damn expensive (I just paid $1200 total for 4 of them).
Also, I would definitely have crunched the front on parking bumpers at least a couple times, probably not hard enough to require body work but hard enough just the same. So I'm trying to do some algebra or calculus or something to figure out if I should lower the car at all and if so how much.
Or maybe there's no calculation that makes any sense and you just have to go "Screw it, it looks gooood." ( in which case I'd still like to have an idea of how long my tires will last.)
Old Nov 23, 2010 | 06:30 PM
clochner's Avatar
Just out of curiosity, what are the advantages to lowering the car?
Old Nov 23, 2010 | 08:14 PM
LeadToRome's Avatar
Looks is a pretty big component of it, the car just looks faster and sleeker when it's lowered and (imo) if you get it into a slightly nose-down posture. the only practical thing I've heard is that it lowers the center of gravity, which helps to control body roll and make the car ride better at speed. There may be other reasons, I dunno.
Old Nov 24, 2010 | 02:18 AM
seinsmeld13's Avatar
As long as you have the car in alignment there will be no difference in tire wear when lowered.
Old Nov 24, 2010 | 04:11 AM
MadMadS4's Avatar
Here ya go, this'll do it.....
Old Nov 24, 2010 | 05:24 AM
boulderbobo's Avatar
+1
Old Nov 24, 2010 | 05:31 PM
LeadToRome's Avatar
I'm pretty sure that you're wrong, that lowering the car puts the front wheel on their inside edge, and the more you lower it, the more it rides on that edge, increasing wear even more. I believe there is no way to adjust the leveling od the front wheels foe reasons having to do with the steering, but the back wheels can be adjusted to ride flat.
Old Nov 24, 2010 | 06:39 PM
As long as it can be put in alignment no issues. I have two lowered cars and both have even tire wear a GTI and a TT. The TT I had to use a camber kit to get it set up right. The GTI they were able to align. I can only tell you what I know based on my personal experience.
Old Nov 24, 2010 | 07:26 PM
Tifosi's Avatar
Correct. The Audi suspension system does not allow for much camber adjustment for the front end. However, alignment can be done by adjusting the sub-frame for cars with factory suspension or if the drop is within the tolerance. An 1" drop is well within that range and a proper alignment take care of your concerns. If we are talking about > 2" of drop, I would recommend aftermarket adjustable control arms such as these ( http://www.purems.com/products/product.php/II=2940 ).
Old Nov 24, 2010 | 07:40 PM
Tifosi's Avatar
If you are referring to the camber adjusting bushing kit that I am thinking of, I had them on my B5-S4 and IMO, are not worth the cost or the trouble.
Also, aren't the suspension system different from the VW's to Audi's, with the exception of the A3's and the TT's ? Which may explain why the bushing kit works are popular among the VW owners and the TT owners but not so much in the Audi circle.
