USB Drives with AMI
Thanks for the info.
I question whether power consumption is the problem since the portable USB3 drive is backward compatible to USB2 @ 500ma, which the MMI supports. Unfortunately, I don't have a USB3 flash drive to experiment with or I could confirm whether the problem is USB3 or power draw.
A pricey option *might* be an SSD drive mounted in a portable enclosure. I like the acomdata branded enclosures (available at amazon) for laptop-sized drives (2.5"). The SSD drive will require less power over the USB cable, and may work. Best idea would be try to find a friend to try his/hers SSD drive before you spend decent $$ on a new SSD just for the car.
