ABS Controller Help!
Three days ago my ABS light came on and the brake light was flashing (3 beeps). After 2 or 3 minutes it went off. It didn't come on again for the remaining two hours of my trip. When I got home I VAG'd it and got these DTCs:
18014 (Rough Road/Engine Torque signal from ABS: Electrical Malfunction P1606-35-10 Intermittent)
01203 (Electrical Connection between ABS and Instrument Cluster, 03-10 No Signal - Intermittent
I cleared the codes and the car was fine for another day, then the lights came on three times in an hour. (By the way, even with the lights on, the ABS works fine, so I don't think the controller or pump are bad) So I STFAd and found the postings on the ABS controller wiring from JasonS4 and WindycityS4. The only problem is that I have an MY2000, which has a different ABS system. I also read on the forums that the ABS module is in foam under the right rear seat. So I unplugged this module, inspected the wiring and pins, cleaned the connections. I also unplugged the ABS controller under the hood connecetd to the pump. The connector was filthy. I hoped this was the problem, so I cleaned it thoroughly and carefully with contact cleaner and a small wire brush. I added some dielectric grease and reconnected. I cleared the codes and all was fine, until this morning, the lights came on twice and went out again in an hour.
So a few questions:
1) Is the ABS Controller the one under the right rear seat in foam? I'm thinking it isn't because I would have had to recode ABS after I disconnected it. What about the one in the middle under the rear seat bolted to the floor?
2) On an MY 2000, how do you recode the ABS? The ones I found on the forum for MY2001 do not work.
3) Any suggestions on tracking down this electrical gremlin?
4) I studied Bentley and believe the culprit is in the wire connected to terminal 10 (green) in the ABS unit. Has anyone had a similar problem? Should my next step be to track down this wire between the ABS unit, T10b connector in A-pillar, A91 connector in instrument panel harness, and J218 instrument cluster processor?
Sorry for the long post, but any help is much appreciated!
I'll keep you guys posted. I don't know what the fix is but something in the electronics on this Bosch unit is teh suck!!
Good Luck.
How do you remove the box from the ABS pump? Does the whole thing have tyo come out?
I think it could cause the intermittent code because if the electronic module has a faulty relay or connection then it causes the intermittent code because the ECU can't talk to the ABS control model in the 20sec intervals it requires.
I will keep you updated. I have a busy Friday, the ABS Module, new spark plugs, change the transmission and gear oil and clean the fuel system with SeaFoam!!
If you do need the ABS unit, I would bit the bullett and get a new one. If this unit fails while driving your wheel can lock up causing some handling problems, like unwanted turns.
Based on the number of failures VW and Audi are experiencing I would venture a recall is in the works. Several of our customers have sent letters to VW of America about this issue.
Good luck.
