with all teh weight reduction talk, what about moving fuel cell to spare tire well, >>
Old Jun 15, 2006 | 08:36 PM
timsias's Avatar
Banned
Default with all teh weight reduction talk, what about moving fuel cell to spare tire well, >>
i think it will help balance out weight differences side to side in car and with battery and fuel cell so much farther back in car and much lower center of gravity wise. any opinions? tia
Old Jun 15, 2006 | 08:38 PM
Tomasz@Startup's Avatar
Default Expensive. You can ask Pat, I am pretty sure he is doing that.
But you are looking at at least $2,000.
Old Jun 15, 2006 | 08:50 PM
Johnny Bravo's Avatar
Default I think the primary focus should be reducing the polar mass
Moving the fuel tank into the spare tire well, will raise it up slightly from its current position, and move it further from the Cg.
The reason this car isnt so willing to turn in, and change direction ( pig on the AutoX ) is the high moment of inertia. In addition to its weight.
"The larger the moment of inertia, the harder it is to rotationally accelerate a system, the more energy is stored in a rotational motion and the larger the angular momentum."
Try moving as much weight as possible, to a position inbetween the wheels. Batterys should go between the wheesls, as such so should the tank remain in its current position.
Old Jun 15, 2006 | 09:13 PM
Snow Trooper *Swiss*'s Avatar
Senior Member
Default sorry, no.
tomasz, i like you but for a "tuner" you are always way off base on the cost to do stuff. stop letting yourself get ripped off by speedware or whoever it is quoting you these crazy prices
Old Jun 15, 2006 | 09:14 PM
Senior Member
Default spare tire well with the hump and canister removed sits lower than the tank
a nice custom built aluminum tank in the 5-8 gallon range would fit there nicely.
Old Jun 15, 2006 | 09:45 PM
Imolavirus@BuehnEngineering's Avatar
Default a custom fuel cell that fits in the spare tire well that is also certified for NASA/SCCA/ect...
isn't going to be cheap
Old Jun 15, 2006 | 10:16 PM
Senior Member
as long as its built to spec, cost depends on how bad the shop building it screws you over
Old Jun 15, 2006 | 10:19 PM
Default No, not really.
The Cg, centriod of that tank, will not be lower than the cg of the current tank. Especially if there is only 8 gallons in the original location.
Plus, that does nothing but increase your polar inertia.
Other things should go in the rear.
Old Jun 16, 2006 | 01:13 AM
S4CFI's Avatar
Put up or shut up. Have one done that will pass a NASA AND SCCA tech inspection
Old Jun 16, 2006 | 07:04 AM
StoneMan's Avatar
EF, Oh EF Where art thou!
