AWE rsk04 updated software results Part 2
Old Aug 30, 2007 | 11:12 AM
GoodMatt's Avatar
Default AWE rsk04 updated software results Part 2
original thread here: https://forums.audiworld.com/s4/msgs/2699743.phtml
I decided to split it up as once a message falls off the main page, it doesn't get much attention.
I'm really happy with the upgrade so far. Before I would often have throttle cut issues. I've got about 125 miles on the new software and haven't experienced one instance of throttle cut.
Boost is quite solid at 21'ish psi.
I do see reduced throttle angle until about 4k rpms in some situations. For instance, if I floor it in 3rd gear at 3000 rpms, the gas pedal angle shows 100%, but the throttle angle will go to about 80%. It will slowly creep up and will reach 100% by 4000 rpms. It feels like turbo lag, but I guess I would say it's throttle lag.
These are the faults I had after 100 miles of driving:
17952 P1544 163
Angle Sender 1 for Throttle Valve Drive -G187: signal too high [Sporadic]
17580 P1172 163
Angle Sender 2 for Throttle Valve Drive -G188: signal too low [Sporadic]
16622 P0238 163
Turbo/Super Charger Boost Sensor (A) Circuit: High [Sporadic]
16497 P0113 163
Intake Air Temperature Sensor 1 Circuit -G42: High [Sporadic]
16502 P0118 163
Engine Coolant Temperature Circuit -G62: High [Sporadic]
16490 P0106 163
Manifold Absolute Pressure/Barometric Pressure Circuit
-G71 / -F96: Range/Performance [Sporadic]
I cleared everything and we'll see what comes back after another few days of driving.
-Matt
Old Aug 30, 2007 | 11:24 AM
visintainer  [vis]'s Avatar
Member
i had the same exact codes yesterday after putting in the new file. mine haven't come back yet
Old Aug 30, 2007 | 11:25 AM
nyet's Avatar
AudiWorld Expert
if they come back try a TBA
Old Aug 30, 2007 | 11:34 AM
J.Moss@TorqueFactory's Avatar
Senior Member
Default When you bench flash an ecu most of those codes are stored. The Ecu is powered up w/o
any of the sensors/actuators connected and it develops most of those funky codes.
Always clear codes after a bench flash.
Old Aug 30, 2007 | 11:38 AM
GoodMatt's Avatar
Thanks for the tip.
Old Aug 30, 2007 | 11:50 AM
BlackS4tt (Josh)'s Avatar
100% throttle at 4k rpms is common in M/T box cars IIRC.
Old Aug 30, 2007 | 01:07 PM
sj6sp's Avatar
Member
It's in the software. My ASP sauce hits 100% @ 3K
Old Aug 30, 2007 | 05:00 PM
rktskicar's Avatar
Let's see a VAG log that shows this.
Old Aug 30, 2007 | 05:45 PM
nyet's Avatar
AudiWorld Expert
Default ...
<center><img src="http://nyet.org/cars/vag/nyet-awe-vs-nyet-lbm-vs-ah-asp/4xECUx_10698_image004.gif"></center><p>
Old Aug 30, 2007 | 05:56 PM
Hal_TT::CBP's Avatar
APR too... thought they all did that until MarkP refreshed my memory.
