Boost issues
Old Feb 11, 2008 | 02:24 PM
HdiaS4's Avatar
Default Boost issues
My car is not meeting the desired boost levels.
I have to "jump start" the boost to reach 21 psi. for example:
On this graph I went WOT, boost only went to 19psi i then let go of the pedal for .5 sec and press it again(WOT) to see the boost just go over to 16.
I do it a couple more times(let go and get on the pedal) till the boost reaches desired level.
Since i have a fixed duty cycle, it indicates a mechanical failure, i have tried a new working n75 and had the same issue.
What other ideas you guys have for me to try.
I pressured tested up to 13psi or so should i try higher?
Thanks
<center>
<img src="http://i101.photobucket.com/albums/m57/hdias4/logs/bad%20boost/MAF.jpg" alt="Photobucket - Video and Image Hosting">&lt;br&gt;&lt;br&gt;
<img src="http://i101.photobucket.com/albums/m57/hdias4/logs/bad%20boost/dutycylce.jpg" alt="Photobucket - Video and Image Hosting">&lt;br&gt;&lt;br&gt;
<img src="http://i101.photobucket.com/albums/m57/hdias4/logs/bad%20boost/Boost.jpg" alt="Photobucket - Video and Image Hosting">&lt;br&gt;&lt;br&gt;
</center>
Old Feb 11, 2008 | 02:47 PM
Aldonis's Avatar
supercold - limp mode? Generating boost to fast?
Old Feb 11, 2008 | 02:50 PM
SoSlow's Avatar
looks like the car is overboosting - i would pressure test the WG lines carefully
Old Feb 11, 2008 | 02:56 PM
The_Jerbel (Jordan)'s Avatar
Junior Member
Looks like a big boost leak somwhere, that or a sticky WG.
Old Feb 11, 2008 | 02:57 PM
HdiaS4's Avatar
Default boost is low, so i thing it could be
boots leak(found none so far)
bad wastegate lines, bad wastegates
bad turbos.
just don;t know.
Old Feb 11, 2008 | 02:59 PM
HdiaS4's Avatar
Default sticky WG is another idea i thought about.
But with the car idling fine and maf numbers going low don't thing could be that massive of a leak.
Old Feb 11, 2008 | 03:00 PM
HdiaS4's Avatar
Default uhmm its not overboosting. its underboosting suppose to go 22 to 20
and only on the final try did it reach 22.
Old Feb 11, 2008 | 03:03 PM
Junior Member
I'm thinking WG's considering what you said about the idle and MAF values.
B5QShip's Avatar
what hardware/software are you running? and do you have a log where you hold 100% throttle?
Old Feb 11, 2008 | 03:05 PM
B5QShip's Avatar
nope
