CEL, Code16985, Control Module Memory Checksum Error
Old Feb 16, 2005 | 02:16 PM
phg60's Avatar
Default CEL, Code16985, Control Module Memory Checksum Error
ARP chip,Can not clear CEL,
Anyone have any luck getting APR to rechip/reflash their ECU?
Old Feb 16, 2005 | 02:21 PM
AudiS4guy - NorCal's Avatar
Member
IIRC bentley says to replace the ECU...Maybe your ECU is toast? Or bad solder job
Old Feb 16, 2005 | 02:47 PM
phg60's Avatar
Default Car runs great, But CEL keeps coming back
Reinstalled APR after last weekend's break in attempt (Anti-theft program)
Old Feb 16, 2005 | 03:03 PM
Jason @ Streetwerke's Avatar
Any qualified APR Distributor can resolve that problem in a 1/2 hour.
Old Feb 16, 2005 | 03:14 PM
VR_Life's Avatar
Guest
Default Either its a checksum because the APR program is corrupt, or because the memory is corrupt
If it's the latter then things like storage of long-term fuel trims may not be working, which could lead to other problems.
I'd try resetting and re-flashing, and if it still doesn't work then I'd be very worried i.e. look at replacing the ECU.
Old Feb 16, 2005 | 03:20 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Just searched...
definitely have the chip reflashed. If that fails to solve the problem, then there is another issue with the ECU and it will need to be replaced.
Don't replace the ECU blindly without first doing the reflash.
Old Feb 16, 2005 | 03:30 PM
DAP@EPL's Avatar
Audiworld Sponsor
Default Or if you have access to an EMCS home progammer, APR should be able to send you the file to do it
yourself.
Old Feb 16, 2005 | 03:34 PM
RKA's Avatar
RKA
AudiWorld Uber User
You can't download the files from the website anymore?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 16, 2005 | 03:37 PM
DAP@EPL's Avatar
Audiworld Sponsor
Not sure if they have the checksum fix one the website.
Old Feb 16, 2005 | 03:51 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Wait, there is a separate file to fix this specific error?
What's the story here? (as in...what is the real cause of the problem, and what has APR done to address it)
