Is the clutch switch covered under cpo???
Old Oct 30, 2006 | 06:53 PM
newguy662's Avatar
Junior Member
Default Is the clutch switch covered under cpo???
i was doing some searching and someone said it might be the clutch switch...
i have to press my clutch down to the floor to start, but shifting is in normal position
Old Oct 30, 2006 | 07:01 PM
daves4izzle::ASP 3-'s Avatar
Default Sounds normal to me...the whole point of having to depress the clutch all the way down is for safety
...just so there is no chance that the clutch is engaged even the slightest bit when the motor is fired up.
Old Oct 30, 2006 | 07:20 PM
stickyS4's Avatar
2nd...no big deal
Old Oct 30, 2006 | 07:38 PM
OSin456's Avatar
Default Pull the cover yourself and adjust it.
I picked up my car and cruise didn't work. Turned out to the the clutch switch. (thought the clutch was depressed when it was actually out so it wouldn't engage. I screwed it in more and I have cruise back. U can pull the kick panel and look at the switch, and adjust it, or CPO will cover it. If you want to know more about your car give it a look. Took me 15-20 mins, and I didn't know really what I was looking for.
If the switch is dead it will need to be replaced, if it is just improperly adjusted you can fix it yourself.
Old Oct 30, 2006 | 08:44 PM
ChucktownS4's Avatar
its pretty easy to adjust it back out yourself stf
Old Oct 31, 2006 | 08:12 AM
Hogothorpe's Avatar
I just replaced mine recently - it's pretty easy. Normal to have to put the pedal to the floor IMO
jav
Audi allroad
Nov 18, 2023 09:27 AM
eigenvector
Oct 30, 2006 06:51 PM
Jesse623
Apr 11, 2006 05:49 PM
GkRiKoRi
Aug 29, 2004 07:33 AM
Calhoun
Nov 18, 2003 02:14 PM
