Coolant sensor help...
Old Apr 20, 2009 | 04:38 AM
  #11
jasonmd's Avatar
Yes it is the drivers side, right under the coolant tank
Old Apr 20, 2009 | 05:25 AM
  #12
Tifosi's Avatar
If your intention is to replace the Engine Coolant Temperture/ECT sensor, according to your photo, it would appear that you have the correct part. But you are working on the WRONG site. The two sensors are completely different and are not interchangable.
Old Apr 20, 2009 | 05:46 AM
  #13
complacentsee's Avatar
Yep, the sensor your looking to replace is in a similar location on the passenger side. Kinda just on the back of the engine, passenger side, easy to spot with a light.
Old Apr 20, 2009 | 05:55 AM
  #14
jasonmd's Avatar
Really? So what you're telling me is that this is a different sensor? This one is under and a little to the left of the coolant tank (as looking at straight on) on the drivers side, right behind the cyl head. It has a c-clip exactly like the new one that I received and I can see an o-ring down in the hole. There is a hose that comes off the coolant tank and connects to another pipe going into the same area, seems to definitely be caring coolant. So what is this sensor that I am looking at? And to confirm you are saying that this "green top" coolant sensor that I need to change is on the passenger side?
Old Apr 20, 2009 | 06:24 AM
  #15
Tifosi's Avatar
If you read my ealier reply to your thread, I have already explained it to you. The sensor on the passanger side is the ECT sensor and the sensor on the driver side is the Engine After-Run pump/fan switch sensor.
They both operate off the coolant tempterture and both uses C-Clip and O-rings but are for two completely different sensors and does completely different things.
Old Apr 20, 2009 | 06:43 AM
  #16
jasonmd's Avatar
Ah, the after-run sensor, so that is what I was working on...sorry if I didn't completely understand. Thanks a lot for the help. I will check it tonight when I get home.
Old Apr 20, 2009 | 03:30 PM
  #17
jasonmd's Avatar
Guys a little more help please? If I spray WD40 in there will that do anything at all? Good or bad :-) I did find the sensor exactly as you described Tifosi, but that sucker won't come out for anything! I have been gently rocking it back and forth, but it hasn't budged. It also looks pretty corroded from the little bit I can see in the edges...
Old Apr 20, 2009 | 04:05 PM
  #18
WD40 shouldn't hurt any thing, but probabaly wont do much of any thing either. Go for twisting and rocking. Maybe even use a pliers, just don't break it in 2.
Old Apr 20, 2009 | 05:10 PM
  #19
jasonmd's Avatar
WooHoo :-) Got it! Nothin a little vice grips can't cure! Thanks guys for the help...
Old Apr 20, 2009 | 05:13 PM
  #20
Tifosi's Avatar
I don't think there is any tricks to it, you just have to be patient and work on it. Remember that it is suppose to be a tight fit, if not, you will be losing coolant from there. By the way, did you open the reservior cap to let the pressure out of the system first and then re-tighten it ? Also, try rocking it in a circular motion and see if that will help losen the sensor a bit. I may even use a little water and a clean, used tooth brush and see if you can loosen some of the rust or dirt out of there.
Regarding the usage of WD40, I am not so sure if that is such a good idea. Coolant circulate through there, any sort of containments to the system is never a good idea. Plus, we don't know if and how the WD40 will react when mixed with G12 coolant. If it causes any type of percipatation of solids, it can gunk up the coolant system. If I were you, especially with hot weather coming, I would have the system flushed and coolant changed soon.
