EFU users: Could you please log boost via VAG-Com (115) or ECU Explorer and compare with EFU #s ?
Old Jan 22, 2007 | 09:54 AM
PSmalls::DoggieStyle's Avatar
Elder Member
Default EFU users: Could you please log boost via VAG-Com (115) or ECU Explorer and compare with EFU #s ?
I have a TCD that does not allow accurate boost logging via VAG/ECUx, but I'd like to see some data comparing the two. Thanks to anyone that actually does this.
Old Jan 22, 2007 | 10:04 AM
Pie4Foo's Avatar
Default Didn't notice any significant discrepancies here.
While my car was on the dyno on Saturday, I manually observed the numbers in the display while ECUx recorded.
Figures seemed inline, but I suppose I could try for a video.<ul><li><a href="http://www.flwse.com/images/steve/Audi_Tech/ECUx/4runs_compare_graph_chris.htm">http://www.flwse.com/images/steve/Audi_Tech/ECUx/4runs_compare_graph_chris.htm</a></li></ul>
Old Jan 22, 2007 | 10:40 AM
Elder Member
Sweet, nice example of EGT enrichment. I'll go take a look at the others now.
Old Jan 22, 2007 | 03:59 PM
Chris.Ranch's Avatar
Default n00bie response
My EFU showed a max value of 16.0 psi, with a logged max value of 4600 mBar absolute.
Was noodling around with conversions and the FATS template, but ran out of time. Could someone show me the light?
Thanks,
Chris
Old Jan 22, 2007 | 04:30 PM
Elder Member
Default 4600 mbar absolute !?!? Wow, that's way more than 16 PSI.
You are asking for a conversion of mbar to psi?
1 bar is 1000 mbar
absolute readings include ambient pressure (actual boost at idle) so you need to subtract that.
~14.5 PSI is 1 bar
If you were to convert your 4600 mbar absolute to PSI assuming 1000 mbar (1 bar) atmospheric pressure, you'd be making ~52.2 PSI.
4600-1000=3600, 3600/1000=3.6, 3.6*14.5=52.2!
Old Jan 22, 2007 | 04:47 PM
Must go retest. That makes NO sense.
jjgs4
10
Jan 24, 2007 10:55 AM
MaxHedrm
Dec 14, 2004 01:58 PM
KingBC
Jul 7, 2004 01:56 PM
avdh
RS 6 Discussion (C5)
Apr 22, 2004 11:25 AM
Digit@lex
VAG-COM Discussion
Apr 30, 2003 10:53 AM
