EGT only 10min :) ...
Old Oct 12, 2008 | 09:43 PM
dzzeiks's Avatar
Junior Member
Default EGT only 10min :) ...
I managed to unbolt and get out drivers side EGT in 10 min.
I only took off Y pipe, took a side coolant tank, unbolted heat shield and with normal 17mm wrench got it!!!
So i say it is doable from engine bay!
Old Oct 12, 2008 | 09:49 PM
rakta *chchchanges's Avatar
Default luck.
2ndary air in the way with tip.
routing harder with tip -- both boxes are mounted together on the passenger side of the back of the throttle body.
and lastly..
it took me 1hr or more, with subframe lowered while doing downpipes. in other words..
SHUTUP :P
Old Oct 12, 2008 | 09:55 PM
dzzeiks's Avatar
Junior Member
I was so happy, because every one told it is PITA, so I was lucky
Old Oct 13, 2008 | 08:06 AM
TK: AP2's Avatar
Junior Member
Default slowEURO here also did the same thing. called me for help with it by the time i got to his house....
he already had everything going back together. he did the same route you did to replace it.
Old Oct 13, 2008 | 08:48 AM
dzzeiks's Avatar
Junior Member
amazing, it can take you days or only 10min, it is a gamble with this car
Need4spdnb
11
May 8, 2004 05:02 AM
bobos
May 18, 2003 10:42 PM
tomboyea
Feb 1, 2002 07:35 PM
mattchow
Oct 14, 2001 11:00 PM
GeoS4V8
Jul 24, 2001 12:54 PM
