EGT sensor code
Old Oct 15, 2007 | 05:59 PM
aielloS4 | .:HBC's Avatar
Default EGT sensor code
I did a log on my VAG and came up with an EGT code a couple days before I went to the track. This has probably been here for a while. Just got a VAG btw.
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
35-10 - - - Intermittent
I cleared it as soon as I seen it two days ago, logged again today and came up with the same code. Would I be losing some performance from this?
Old Oct 15, 2007 | 06:01 PM
S40RCE:Smurf's Avatar
yes you would lose performance and maybe trigger limp mode at times.(happened with friends S4)
Old Oct 15, 2007 | 06:05 PM
Default I've noticed limp mode at times but this happens once in a while. I get no CEL so ..
this code has probably been here since I bought my car.
Old Oct 15, 2007 | 06:07 PM
quickaudi:STFA's Avatar
I never got a CEL with mine, yes you'll lose performance.
Old Oct 15, 2007 | 06:18 PM
Would the boost be affected because it is running the same as it usually does?
Old Oct 15, 2007 | 06:21 PM
Re: Would the boost be affected because it is running the same boost as it usually does?
Old Oct 15, 2007 | 06:30 PM
Default if you're stock, you won't notice much of a difference, though you'll run richer.
your boost gauge says what?
rktskicar's Avatar
How long have you had this code? I have seen the same one in last couple of weeks.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 15, 2007 | 06:34 PM
Default im running an mbc/tcd,giac x, 2.5 catback exhaust. Running 18psi and havent noticed any drop..
do you think im not noticing boost drop because boost is not being controlled electronically by the N75 valve anymore? I have the MBC setup in standalone.
Old Oct 15, 2007 | 06:51 PM
laissezfaire's Avatar
I most certainly did. I had both sensors replaced.
