had to refill my coolant for the 2nd time this month... is this bad?
Old Feb 7, 2005 | 10:27 AM
s4gonebabygone's Avatar
Default had to refill my coolant for the 2nd time this month... is this bad?
there don't appear to be any leaks, never anything under the car after it's been parked, but i filled my coolant about 3-4 weeks ago (it had dropped well below the minimum line, there was almost none in the reservoir in the engine bay) and it's happened again now.
could this be a major issue? the car's probably been driven less than 500 miles since i topped it off last time, and again, there's almost nothing in the reservoir. it has not been driven hard, and it's the winter. it's getting me a bit worried now.
Old Feb 7, 2005 | 10:30 AM
DAP@EPL's Avatar
Audiworld Sponsor
Default Not good. If the coolant is leaking and you can't find the leak that can be very bad.
It might be leaking into the oil.
-Dave Pramanik
Old Feb 7, 2005 | 10:32 AM
UKS4APR1's Avatar
Could be your after-run coolant pump, common, do a SITFA
RKA's Avatar
RKA
AudiWorld Uber User
Default That's a problem.
A few potential sources for leaks are the aux water pump under the intake manifold, bad hose near the reservoir, or a cracked nipple at the reservoir. If the leak is small enough, the coolant escapes in the form of vapor, leaving very little trace of the leak. Still, if you look carefully, you'll usually see some white crusty remains (dried coolant).
Old Feb 7, 2005 | 10:53 AM
GrandPaJohn's Avatar
That "crusty" stuff could be pink :-)
Old Feb 7, 2005 | 11:20 AM
S4carl's Avatar
Default Re: Not good. If the coolant is leaking and you can't find the leak that can be very bad.
What? How? I ahve a small coolant leak too and cannot find it...
Old Feb 7, 2005 | 11:47 AM
sizquik's Avatar
Default My "T" adapter had a crack in it, check that
<center><img src="http://pictureposter.audiworld.com/36702/leak.jpg"></center><p>
Old Feb 7, 2005 | 01:13 PM
O.W. Kenobi's Avatar
Rest In Peace
Get an oil analysis with your next oil change to see how much (if any) is in your oil.
Old Feb 7, 2005 | 01:25 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Meh...I'd get a UV dye, drop it in the tank...
and run a blacklight under/over the engine to find the leak. Odds are pretty slim it's ending up in the oil.
Old Feb 7, 2005 | 02:48 PM
DocWyte's Avatar
Could be the heater core, same thing happened to my A4...
