How much power are K04/K16 turbos good for vs PJ K04's? Also, who makes K04/K16
Old Aug 3, 2008 | 02:35 AM
2001s4loored's Avatar
Default How much power are K04/K16 turbos good for vs PJ K04's? Also, who makes K04/K16
specific fueling?
Old Aug 3, 2008 | 04:59 AM
BlackS4tt (Josh)'s Avatar
Default I think the popular choices of KO4 hybrids nowadays are either RS6 compressors, or the 997
compressors. I believe there were some issues with the K16's? Look into that... something about internal pressure of the turbo IIRC.
You should look into some genuine RS6 turbos though... The RS4 KO4s are limited by their hot side.
As far as tuning, i don't believe anyone makes an OTS kit for KO4/K16. Any knowledgeable tuner should be able to set you up with hardware/tuning no problem though. I went with Vast's setup.
Old Aug 3, 2008 | 06:28 AM
DocSlowMiniPerson's Avatar
Junior Member
Default Skip K04/K16s. Many of us tried them and most didn't have good results. Go RS6/K04s if you want a...
K04 based hybrid. Then again, for that much money you are better off doing straight RS6s IMO. I'd never mess with a K04 hybrid ever again with the other options available these days.
Old Aug 3, 2008 | 06:38 AM
Junior Member
Default Here is a mini timeline of how my K16 hybrid experience went with links to a few old posts...
First, Jacob hand delivered one of many sets of turbos I had in my possession before finally settling on a set to install:
<a href="https://forums.audiworld.com/s4/msgs/1704445.phtml">https://forums.audiworld.com/s4/msgs/1704445.phtml</a>
Then, I had them installed almost a year later:
<a href="https://forums.audiworld.com/s4/msgs/1950850.phtml">https://forums.audiworld.com/s4/msgs/1950850.phtml</a>
Finally, I had them replaced with OEM K04s after they started leaking oil externally.
<a href="https://forums.audiworld.com/s4/msgs/2036324.phtml">https://forums.audiworld.com/s4/msgs/2036324.phtml</a>
Old Aug 3, 2008 | 06:46 AM
DAP@EPL's Avatar
Audiworld Sponsor
Default Agreed. K04/K16s have shown to be worse than straight K04s. K04/997 hybrids are good...
as are straight RS6 turbos.
Old Aug 3, 2008 | 06:52 AM
Junior Member
The price of 997/K04s is approaching straight RS6s, maybe only ~$200 difference total.
Old Aug 3, 2008 | 08:04 AM
Default But what if I will be getting a set completely rebuilt with new CHRA's for under
$2000 total?
Old Aug 3, 2008 | 09:55 AM
Junior Member
In that case, DO IT!
Old Aug 3, 2008 | 10:04 AM
Alright, thanks...are they a good turbo otherwise if I am just running K04 software for now?
Old Aug 3, 2008 | 11:40 AM
Junior Member
It won't be optimized, but it should work very well. I'm assuming you mean RS6/K04s, not K16s...
