MTM Dyno Plot
Old Aug 8, 2001 | 08:55 AM
steved's Avatar
New Member
Default MTM Dyno Plot
<center><img src="http://www.ultimategarage.com/S4WG3.JPG"></center><p>Car is 2000 S4 6-speed with MTM chip. Note that car makes over 200 ft lbs torque at 2000rpms. HP maxes at 5075rpm. This is hp at the wheels...figure 20-25% correction factor for flywheel hp. Thanks to Page Pokler for plotting the charts. SD
Old Aug 8, 2001 | 08:56 AM
LCP's Avatar
LCP
AudiWorld Expert
What about the 1600+ rpms past 5358?
Old Aug 8, 2001 | 08:58 AM
steved's Avatar
New Member
Default Torque Makes Boost - Curves are practically identical
<center><img src="http://www.ultimategarage.com/S4WG2.JPG"></center><p>Max boost is 17.3 psi (stock was around 6.5psi). Temps were warm at test time...around 85-90F. SD
Old Aug 8, 2001 | 09:02 AM
steved's Avatar
New Member
Default AFR vs Corrected HP
<center><img src="http://www.ultimategarage.com/S4WG1.JPG"></center><p>Starts out around lambda (afr of 14.7) but MTM adds lots of fuel as boost increases. I don't know why they don't flatten the fuel to around 13-13.6. I suspect there is improvement to be made here. SD
Old Aug 8, 2001 | 09:06 AM
bitrbo's Avatar
Junior Member
Only corrected 256 hp?
Old Aug 8, 2001 | 09:07 AM
Psyence's Avatar
Junior Member
Default For those wondering...
AFR Comment
6.0 Rich Burn Limit (fully warm engine)
9.0 Black smoke/low power
11.5 Approximate Rich Best Torque at wide-open throttle
12.2 Safe Best Power at wide-open throttle
13.3 Approximate Lean Best Torque
14.6 Stoichiometric AFR (chemically ideal)
15.5 Lean Cruise
16.5 Usual Best economy
18.0 Carburetted Lean Burn Limit
22+ EEC/EFI Lean Burn Limit
EEC (Evaporative Emissions Control), EFI (Electronic Fuel Injection)
Taner Halicioglu's Avatar
Default uh... hmmm.. why does HP max out (flatline, too) at 256?
Don't tell me they used a byte to represent HP??
And yeah, what about the rest of the way to redline?
Oh, and I hope you really mean wheel HP... the car is supposed to be 250HP at the crank *STOCK* :-)
-T
BenM@University Audi's Avatar
Former Vendor
Default Looks kinda like this dyno plot.
On a mustang dynometer in Redmond...the intercoolers were soaked with water to get these results.
<img src="http://www.s4.org/joshd/images/dyno/AMSvsMTM.jpg">
steved's Avatar
New Member
Default Need Data???? (Warning-large file-206k)
<center><img src="http://www.ultimategarage.com/S4WG4.JPG"></center><p>Sampling of Dynapack data from a 7 second run. SD
Old Aug 8, 2001 | 09:13 AM
steved's Avatar
New Member
Default SAE corrected - this is rear wheel HP.
The power correction factor is in the data chart. Corrected for temp, baro & humidity. SD
