my06/00 is still sitting uneven, on intrax/koni,i bought the earlier perches but
i am sick of being uneven.
i want to know if anybody has been able to fix this problem and what you did to fix it.
believe it or no, i feel like my car is higher than when it was cornered balanced at 25.5
i know that the coilovers have adjustments between a 15-21 setting, i've always wondered if the person who installed them (istook) messed something up. the compression feels off and i feel too loose going into a corner.
can any one please tell me what to do about this, i went ahead and ordered the other perches for 2001 but im not sure if that will help at all.
If you are going to modify the suspension, get coilovers. They cost more to start, but considering that they work - they are well worth it.
Disclaimer, I sell (and love) Vogtlands and Penskes. (Vogtland for street, Penske for track.)
2nd...when people put different springs on their cars, they generally put the same rate on the front (same rate on both corners) and different rates on the rear (same on each rear corner). The problem with this, is the corner weights of a street car will almost never be truly balanced with the driver sitting in the car. When you start corner weighting the car to get the balance closer, you do this by altering the ride height...up or down on the corners and on the heavy/light sides. The end result will be a car that the ride height is off kilter from where you want it to be.
The true way to balance the car would be not only with ride height set, but slightly altering the spring rates from side to side and corner to corner to adequately get the weights and the height adjusted together. You might wind up with (just an example) 550 left front and 500 right front, and two different weights on the rear.
On a race car, that is the way it would be done...unfortunately, a street car is not set up that way because it costs and takes a lot more time and effort, and springs are generally sold in pairs. Also, with all the rubber in the suspension, the motor mounts, and the subframes, it doesn't react the same.
Example, our new TT race car with stock springs is almost exactly 60/40 front to rear with the front split 50/50...without driver installed. You put 200 lbs in the drivers seat and then all the corners get screwy. To adjust the coner weights, you would have to reset the ride height, and then you would get differences in the corners.
hope all is well.
scott thomas
